Starter issue when running errands .. weird (read)
Old Mar 16, 2010 | 01:47 PM
01RedCLS's Avatar
In the last few months (and it has escalated the last few weeks - spring thaw? got me), when I start the car after it has sat for half-a-day (like at work), and go run an errand, the car hesitates to start and nearly DIES when I try to leave! Usually occurs after I've gone from work to the grocery store, for example, and then leave the grocery store after only allowing the car to sit for 10-15 minutes TOPS.
Any ideas? I haven't changed my plugs yet .. car has 91k miles now. Timing belt and other belts are done, fuse replaced connecting to fuel pump, fuel pump replaced (long story, wasn't the issue but hey, it's new).
Old Mar 16, 2010 | 01:54 PM
Nersh7's Avatar
I Drive Like A Dick 8≈
sounds like your battery is almost dead
Old Mar 16, 2010 | 01:57 PM
01RedCLS's Avatar
Oh and I bought a new battery (Diehard Gold) in November .
Old Mar 16, 2010 | 02:11 PM
Nersh7's Avatar
maybe your alternator??
start the car and disconnect the battery if the car dies I'd say thats a good sign that your alternator is dead or dying
Old Mar 16, 2010 | 03:14 PM
CL-S6's Avatar
Turbo 6 Speed
It could be your fuel/starter relay. Does this usually happen what the car is hot?
Old Mar 16, 2010 | 07:45 PM
aznboi2424's Avatar
I think its a common problem, check the FAQ. something about hard starts when the engine is hot
Old Mar 22, 2010 | 10:59 AM
01RedCLS's Avatar
It happens when the car is hot, yes.
Will check the FAQ now..
Old Mar 22, 2010 | 11:06 AM
01RedCLS's Avatar
For some reason, the CL FAQ is gone from Geocities and I can't seem to find it here lol
I checked here: https://acurazine.com/forums/2g-cl-frequently-asked-questions-52/chodthewackos-acura-cl-faq-page-467288/
Old Mar 22, 2010 | 01:00 PM
phee's Avatar
I got the Shifts
its the main relay. replace it. problem solved
Old Mar 22, 2010 | 01:11 PM
01RedCLS's Avatar
I replaced the fuel relay when I replaced the fuel pump - ended up being a bad fuse, who'd have thunk?
So that's not the issue here, assuming "main relay" is the same as the fuel relay...can you clarify?
Old Mar 26, 2010 | 10:58 PM
newbster's Avatar
This happens to my car in the Spring Months-I live in the Midwest where there is winter blended fuel and as a result, the car will stall or be hard to start after sitting for about 10 minutes or more. I have never had a problem with it because it usually cranks over on the second or third try. I have read that replacing the powertrain computer should resolve the issue as well as the fuel-pressure regulator as previously mentioned.
Hope that helps
Old Mar 27, 2010 | 05:45 AM
rondog's Avatar
Former Sponsor
Make sure the battery connection is absolutely not loose, also, did you inspect the spark plugs? I have a problem with the car takes just a few more turns to catch on, but once it's on, it doesn't sputter or anything. Did you do a scan to see if anything shows up?
Old Mar 27, 2010 | 08:26 AM
CL-S progression 01's Avatar
lowrd on tein CS biatch
no one has mentioned this..:
on my previous car it didn't have the purge solenoid for the fuel lines therefore when u park the car on a hot day vapor builds up in the fuel rails and when u start the car the first throttle or 2 will be wonky cause it's not pressurized liquid gasoline, it's just vapor.
MAYBE this may be indicative or ur problem ?
just a thought budy
Old Nov 2, 2012 | 12:34 AM
kik's Avatar
kik
Which fuse please? I'm having the same exact problem and it would be nice to avoid changing out the main relay. Thanks!
Old Nov 2, 2012 | 03:03 AM
FwC's Avatar
FwC
Just change out the main relay if you haven't already. Sounds like possible vacuum leak. I've had issues with thermostat sensor being dirty and causing my engine to spudder (MAF was cleaned at the same time, that might have fixed it). Engine mount control system vacuum line?
Old Nov 2, 2012 | 01:06 PM
01RedCLS's Avatar
I can't recall but it was blue, related to the fuel pump/system and 15A, I think.
mada51589
Jan 9, 2025 04:40 PM
giovane
2G RDX DIY & FAQ
Jul 8, 2016 10:46 PM
SilverJ
1/2G MDX (2001-2013)
Sep 21, 2015 02:40 PM
PortlandRL
Sep 14, 2015 12:01 PM
whitesoxsfan12
Sep 7, 2015 04:07 PM
