SRS Light?
Old Jan 13, 2005 | 06:10 AM
Sims's Avatar
SRS Light?
Any particular reason the SRS light would come on at -30C outside? Was on when I started up for work this morning, figure its weather related since its retarted cold out. Any thoughts?
2001 CL-S
Old Jan 13, 2005 | 06:52 AM
pawsox5jc's Avatar
i dont know about the second gens. but it has been a common problem for the SRS light to randomly come on in the first gens. there was a simple way to reset it using a paper clip and it has seemed to work for everyone. I did a search and found this, posted about second gens.
Originally Posted by G-UNIT
Paperclip fix....
It is a yellow connector with two wires in it that is plugged into the fuse box, unplug it and pull it down. Once you have done that you can begin the process of erasing the memory. NOTE: This will only reset your SRS System if what caused it to trigger has been fixed, Ex: turning the ignition on with any SRS Plugs disconnected, such as pulling your seat out.
1st step in erasing the memory is to turn the ignition off and connect the SCS Service connector to the MES Plug,
2nd Turn Ignition on. SRS indicator light will come on for about 6 seconds then go off.
3rd Disconnect SCS service connector for MES connector within 4 seconds after SRS indicator light goes off. SRS indicator light will come on again.
4th Reconnect SCS service connector the MES connector within 4 seconds after SRS light comes on. SRS indicator light will go off.
5th Disconnect SCS service connector from MES connector within 4 seconds. SRS indicator light will indicate that memory is erased by blinking 2 times.
6th Turn ignition off, and wait 10 seconds. Start vehicle like normal and light should come on and go out like normal. You have reset your SRS light, congrats.
If it does not work the first time try it again, the timing has to be perfect. My first time it took me 3 attempts before it worked, but it did work.
Old Jan 13, 2005 | 08:09 AM
clswhite's Avatar
Lightbulb
I have the same problem with my 2001 CL-S at low temps until engine bay heats up. The problem relates to brake fluid level, moisture (frost / ice), and the sensor on fluid reservoir. Check the brake fluid level and remove any moisture like ice or frost on the reservoir cap. My
Old Jan 13, 2005 | 12:05 PM
Sims's Avatar
That could be it. Low temps is a mild understatement though lol. today is supposed to be about -43 with windchill.. just frickin rediculous.. should've stayed home.
Old Jan 13, 2005 | 03:54 PM
Dan's Avatar
Dan
Confused
-30C!!! You got to move somewhere else.
Old Jan 13, 2005 | 08:23 PM
underdog's Avatar
I am #76,361,211,935
Mine does it too. The SRS sensor in the passenger side seat is real sensitive
and cold can mess it up temporarily. If its really cold the VSA and ABS
lights come on too for the first couple kilometers, but as things warm up and
loosen up it all 'gets better'.
Old Jan 13, 2005 | 09:00 PM
rjp's Avatar
rjp
CL-S Owner
Nothing like sitting down on leather seats at -33 ... definitely wakes you up in the morning.
Old Jan 13, 2005 | 10:50 PM
doublern2003's Avatar
They sell remote starters in Canada?
Old Jan 13, 2005 | 11:26 PM
Sims's Avatar
yeah I'm thinking of getting a remote starter installed. Dont we need some bypass device for the stock alarm that makes a remote starter more expensive?
Old Jan 14, 2005 | 07:31 AM
RaviNJCLs's Avatar
Might be better than freezing you ass off though. Did the quick fix work? I had to take my CL back to the dealer twice for the SRS light issue. They never gave me a hard time about fixing it though.
Old Jan 14, 2005 | 10:00 AM
ccannizz11's Avatar
My Work is Done Here
To get a remote starter added in is inexpensive for the actual starter. But I've been lookin around recently, and the reaction that I get every time I go into a store to ask is, "Um, that's a complicated car to set up". Apparently, there are a whole bunch of extra parts that need to be included.
I was looking at Circuit City here in MN, they were the cheapest so far, and for a quality remote start, it was going to be about $300 US, even though the actual starter was on sale for about $70. Luckily I'm no paying for it
Old Jan 14, 2005 | 11:51 AM
bgsm1th's Avatar
on to the next one...
My SRS light came on today for the first time since I had my car. It's about -10F here with a windchill of -35. I just had the break fluid flushed and filled about 3 months ago, so that should be topped off nicely. Will it turn off eventually?
Shops around MN will either just not even try to install a remote starter on our cars...or the'll charge you up the ass...what is it about out cars that makes it so difficult to install a remote starter anyway?
B
Old Jan 14, 2005 | 12:17 PM
clswhite's Avatar
Red face
.....The problem relates to brake fluid level, moisture (frost / ice), and the sensor on fluid reservoir. Check the brake fluid level and remove any moisture like ice or frost on the reservoir cap.
Sorry, got my Brake light and SRS (supplemental restraint system) light confused in my brain. The problem has nothing to do with the brakes, but it does relate to the temperature. The seat sensor gets screwed up in cold weather until car interior heats up. Has to do with the leather and foam not being compliant in cold weather.
Old Jan 14, 2005 | 02:33 PM
Sims's Avatar
I havent bothered to attempt to reset it yet. Supposed to warm up for monday. Like -8c or so, if its still on then I will do it. Figure it was the cold.. -30c ambient is just stupid.
Old Jan 30, 2005 | 04:42 PM
convitcon's Avatar
bump
mada51589
Jan 9, 2025 04:40 PM
Dec 7, 2020 05:39 PM
mugen_kid
Nov 13, 2015 10:38 PM
sockr1
Oct 1, 2015 01:31 AM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
