So here is what failed in my tranny...
Old Dec 4, 2008 | 07:24 PM
artbran's Avatar
666 Speed
well... after some trouble with my password (unknown reasons and problems. I would get emails that the page was updated but i could not log on and when I would ask for a password reset, I would get nothing in my email inbox, spam, trash, and so on), I am finally back...
Anyway, its the most expensive of all the gear sets, ($450).
I am rebuilding the tranny and am going to put it up for sale as a freshly rebuilt trans. BTW, its not me rebuilding it, however a Honda tech who specializes in tranny swaps, rebuilds and so on. The tranny is at Honda now in parts..
Either way, here are the pics (BTW, this is the CLS6 tranny. Turned out to be that the gear had a weak spot/defect in the cast that reared its ugly head 100,000 miles later. Oh and its second gear like I stated):
Old Dec 4, 2008 | 07:28 PM
CL6's Avatar
CL6
My only car is a Bus
Damn!
artbran's Avatar
666 Speed
Luckily, nothing else in the tranny was damaged. Everything else is 100%. No burrs anywhere in the other gears or anything. Its all good.
The entire tranny has been through a parts washer already and is ready to have a new second gear set pressed in.
And for those who cant see it all that well, thats a whole tooth missing along with 2/3 of each tooth above and below it (so only 1/3 left of each). Gear showed a weak spot on it when just looking at it along with when they took the gear off and put it through a sonic test..
Old Dec 4, 2008 | 10:34 PM
CH46ESeaKnight's Avatar
Ouch man, that brings back bad memories!
Are you changing anything else in the tranny?
Old Dec 4, 2008 | 11:26 PM
CL6's Avatar
CL6
So it was a casting error? I'm surprised it lasted so long. Is this a first?
Old Dec 5, 2008 | 08:23 AM
GRNMCHN03cl's Avatar
I don't know but cryo treating it might be a good idea possibly?
Old Dec 5, 2008 | 11:58 AM
97supratt's Avatar
8th Gear
That's very very odd. I haven't seen something like that in a while. It has to be a bad casting that just took a long time to break off. BTW is your supra single ? I used to have a 97 RSP auto that was bpu a while back.
Old Dec 5, 2008 | 11:20 PM
salcls's Avatar
http://img168.imageshack.
How much?!? I might need a new tranny...
Old Dec 6, 2008 | 12:13 AM
BigLizard's Avatar
Moderator Alumnus
Jesus people...this isn't the damn black market...if he's going to sell he'll do it there...NOT HERE!
Old Dec 6, 2008 | 02:57 PM
TheWeez's Avatar
I Wanna Beer
Seems like a bit of a waste unless you're running a lot of boost. Even then the clutch is going to be the weak point.
Old Dec 6, 2008 | 04:04 PM
Wow, someones in a pissy mood. Way to treat people.
Don't appreciate the religious slur on the forum asswipe!
Old Dec 6, 2008 | 04:07 PM
Artbran, did you just buy a new one, and rebuilding the old one? How much did the new one run you? Just curious.
Old Dec 6, 2008 | 06:36 PM
BigLizard's Avatar
Moderator Alumnus
I've asked a lot of people in artban's threads from the past to not turn his threads into BM "dibs" threads...
I don't appreciate the fact that some people don't listen.
BTW...not a nice way to treat a MOD. You've been warned.
kthxbye
Old Dec 8, 2008 | 12:45 AM
YeuEmMaiMai's Avatar
didn't the casings get updated to deal with the oiling problems? are they putting a new case on it?
Old Dec 9, 2008 | 11:24 AM
artbran's Avatar
666 Speed
check the black market. I have a thread there with a solution to the problem.
I bought a totaled CLS6 with I stripped and took the tranny from.
Since second gear is the one that died, I looked into replacements. Its the most expensive gear set in the whole tranny. $450. Now as it turns out, its the same gear set as in the 04-07 TL 6sp and the AV6 6sp. So I'm looking for dead cars/trannies to pull the parts from OR Someone send me a deposit for the part, I have my certified Honda Transmission specialist friend rebuild the tranny to factory specs, they send me the balance and I crate the tranny to them.
Old Dec 9, 2008 | 04:02 PM
artbran's Avatar
666 Speed
The Supra was just converted to single when the stock twins died. Turbo #1's shaft bent and #2 was leaking oil sooo out they went and in went a single.
It is the kit that was banned from supra forums as they say (XSPower) but the car is not driven all that often (MAYBE once a week considering its a show car) so something that would have run me $4000+ was out of the question. NOT ONLY SO, I spoke with the guy who makes these kits (lets call him Mark) and he has sold many of these kits and they all last a long time. He only has a low % return rate for broken/bad turbo's and manifolds, but the downpipes have some small fitment issues sometimes, but its not something that cant be fixed by rotating the pipe.
What I can tell you though is what this turbo does at 8psi is what the stock's did at 18-20 (on a spike). This one is just much much more efficient than the stock twins.
Now, back to the tranny, It was casting problems as you can clearly see it when you are looking at the gear. There is a "mixture" between the 2 metals that didnt fuse properly. As well as the the way that the teeth broke. Its missing the same amount on both sides as well as the center tooth. I dont have the print out of the test, however they said that "Honda f*cked up."
udelslayer
1G RDX Problems & Fixes
May 6, 2016 12:27 PM
MilanoRedDashR
Oct 2, 2015 10:49 AM
kb1rl
Sep 30, 2015 10:17 AM
JDMVP
1G TL (1996-1998)
Sep 17, 2015 06:14 PM
gqdabien
Sep 8, 2015 11:41 PM
