Seat heater
8th Gear
Obviously, check all your fuses. Make sure the connection under your seat is plugged in. And, if worse comes to worse, you may have to pull your seat and open it up to verify that all your connections are good on it. If they are, try a direct line from the battery to the positivte wire on the plug, and ground it, just temporarily to determine what the problem is. The thing with troubleshooting electronics is using the process of elimination, and trying one thing at a time.
Good luck.
Good luck.
I miss my 03 CL-S :(
Originally posted by RobOnLI
Driver's backrest doesn't have a heating element. Only the butts on both seats and the back on the passenger's seat.
The driver has both bottom and back heating elements. RTFM
![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
