Seat heater
Old Nov 26, 2003 | 04:47 PM
AKYPA's Avatar
Seat heater
Any idea why my seat heater dosn't work?
2003 tl-s. Thanks
Old Nov 26, 2003 | 04:52 PM
einsatz's Avatar
I miss my 03 CL-S :(
I think it's broken.
Old Nov 26, 2003 | 05:17 PM
Ant7701's Avatar
Sweet as Gold
I know it's broken...
Old Nov 26, 2003 | 05:36 PM
gdubb's Avatar
Mazda3 and Honda Civic in
lol
Old Nov 26, 2003 | 09:55 PM
Mudd's Avatar
8th Gear
Obviously, check all your fuses. Make sure the connection under your seat is plugged in. And, if worse comes to worse, you may have to pull your seat and open it up to verify that all your connections are good on it. If they are, try a direct line from the battery to the positivte wire on the plug, and ground it, just temporarily to determine what the problem is. The thing with troubleshooting electronics is using the process of elimination, and trying one thing at a time.
Good luck.
Old Nov 26, 2003 | 10:03 PM
Ant7701's Avatar
Sweet as Gold
Or...you can go to the dealer and take advantage of your warranty...common failure...we do a good amount of seat heater pads.
Old Nov 26, 2003 | 10:31 PM
Cruz_msl's Avatar
My Member is Registered
Old Nov 26, 2003 | 10:32 PM
Cruz_msl's Avatar
My driver's back rest doesn't work. Dealer next week
Old Nov 27, 2003 | 09:08 AM
RobOnLI's Avatar
I'm out of HELL!!!!
Driver's backrest doesn't have a heating element. Only the butts on both seats and the back on the passenger's seat.
Old Nov 27, 2003 | 10:04 AM
einsatz's Avatar
You got it backwards. It's the back of the passenger's seat that doesn't have heat.
The driver has both bottom and back heating elements. RTFM
Old Nov 28, 2003 | 11:41 AM
SanMarinoTypeS's Avatar
Just brought the the car into the dealer for the same problem, No heat on the back, Turns out to be the heating element. Dealer had to order the part.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
tsx_boy
Dec 13, 2019 08:33 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
hashbrown
Sep 29, 2015 12:13 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
