S/C Gauges
Old Apr 20, 2005 | 01:32 AM
NiteQwill's Avatar
Adventurist.
Red face S/C Gauges
I'm having difficulty picking out the gauges I need.
Please correct me if I'm wrong...
For Fuel: I need a 0-100 sweep
For Boost: I need something up to 15psi (this is most of the trouble)
I've looked at Auto Meter, which series should I look for?
As far as mechanical and electrical; should I choose a mechanical boost and electrical fuel (for safety)?
I'm getting the gauge pod from www.gaugepods.com
Thanks guys!
Old Apr 20, 2005 | 02:39 AM
rtatsutani's Avatar
Never had a clean run
Always get electrical for fuel pressure if you're going to mount the gauge in the the car.
Old Apr 20, 2005 | 02:42 AM
Edddie's Avatar
Get a parachute and ejector seat. You'll need it when you get too much altitude.
Get as many gauges as possible, just for piece of mind.
Old Apr 20, 2005 | 03:57 AM
brianlin87's Avatar
ASM I.S. Design FTW.
i knew it was only a matter of time before i saw an s/c on your ride... good stuff dustin
Old Apr 20, 2005 | 06:47 AM
babyblue's Avatar
Sold but not Forgotten...
Well I went with the following gauges....
Phantom Series Gauges - 5763, and 5776...
Edit: The reason I went with this line was primarly to do with the boost gauge maxing out at 15 psi... No need for those 30 psi ones sinces our cars dont boost that high with the SC...
Old Apr 20, 2005 | 09:15 AM
NiteQwill's Avatar
Adventurist.
Those are the gauges I'm getting! I was looking at those.
How much did you pay and where? Thank you.
Old Apr 20, 2005 | 09:53 AM
Smitty's Avatar
when I shopped around: Lane Automotive had the best prices... but you have to call them.
Old Apr 20, 2005 | 11:00 AM
babyblue's Avatar
Well since I live in the frozen north .... It gonna cost u for duties and taxes if you buy from here... Believe Chap has the same ones as well...
Edit: Link below for US Suppliers
http://www.prostreetonline.com/store...hantom_gauges/
cheapest so far is in the link below:
http://www.tbyrnemotorsports.com/Cad...ctsgauges.html
204.99 for the fuel pressure
169.99 for the boost/vac
Did you get ur SC yet???
Old Apr 20, 2005 | 02:08 PM
mrsteve's Avatar
Ultra Lite Pro Comp gauges have a silver face with almost perfectly match the gauges on the dash.
They have a 15psi boost gauges too.
#4376
#4363
Old Apr 20, 2005 | 03:08 PM
Allout's Avatar
Blown is Best
What are you guys doing if you want a third gauge for wideband AF? Is there a 3 gauge pod available?
Old Apr 20, 2005 | 03:14 PM
mrsteve's Avatar
Unfortunately there isn't. We'd need to get another group buy organized for them to make a 3 pod pillar.
Smitty and I ended up hacking our 2-pod pillars and adding this autometer universal gauge mount. It actually looked good once installed. I don't have any post-install pics right now though...
Old Apr 20, 2005 | 03:19 PM
Allout's Avatar
Blown is Best
If you were to pick just two gauges to fill the two pods only, which two gauges would you pick? Boost & AF?
Also, are any of the dual gauges any good?
Old Apr 20, 2005 | 03:22 PM
mrsteve's Avatar
Fuel pressure is priority #1. After that A/F will probably tell you more than a boost gauge would. If your belt is slipping you'll hear it. It's not like we are running turbos where we can overboost... you nail the throttle, you get peak boost... everytime
Old Apr 20, 2005 | 04:18 PM
Jleev6's Avatar
Supercharged
I am using the ultralite air fule ratio and the boost vacuum gauges in my supercharged accord.
Hey MRSTEVE, just wondering why the fuel pressure gauge is so necessary. Should I be getting one of these? Thanks.
Old Apr 20, 2005 | 04:28 PM
mrsteve's Avatar
The Comptech FPR has been known to fail. Low fuel pressure could lead to the engine stalling, engine knock (detonation), etc. Too high fuel pressure will lead to rough idle, and rough partial throttle conditions, as well as fouled spark plugs.
Ask the other guys who really know what they are talking about. Monitoring fuel pressure really is important. A boost gauge just looks nice
Old Apr 20, 2005 | 08:47 PM
babyblue's Avatar
Wanted to ask... getting the gauges installed this weekend.. what is the norm for the fuel pressure at idle and at WOT... Thanks
Old Apr 20, 2005 | 09:05 PM
Allout's Avatar
Blown is Best
What's the downside of going with a manual Vac/Boost gauge? They sure are a lot cheaper.
Old Apr 20, 2005 | 09:10 PM
mrsteve's Avatar
Just not as nice, not self calibrating, don't match the fuel pressure gauge, etc. Manual gauges are actually more accurate than the full swept electrical gauges.
mrsteve's Avatar
Around 37-40psi at idle. 100psi at WOT and around 95psi at redline.
Old Apr 20, 2005 | 10:20 PM
NiteQwill's Avatar
Adventurist.
I'm going for the Ultra-Lite Boost & Fuel. I wanted something that will match the car overall and I really like the silver look.
btw: for the fuel, what wire did you guys tap in order to send the signal?
I'll keep you guys updated. Thanks, you guys are great!
Jul 16, 2017 07:33 AM
BOOSTED6IX-S
Feb 22, 2016 01:53 PM
CL-S progression 01
Jan 26, 2016 04:15 PM
Sep 21, 2015 08:44 AM
