Rougher ride after alignment...
Old Jul 31, 2005 | 04:18 PM
icy CL's Avatar
i had my alignment done about two weeks ago and i noticed my drive is a lot rougher. tires pressure is the same as it has always been....32psi on both front and rears. after the alignment, i notice i feel every single bump regardless of size. and now, if i hit a road bump, i feel the road more and its like there are aftershocks after each bump. can anyone explain....
Old Jul 31, 2005 | 04:44 PM
Allout's Avatar
Blown is Best
Did you get a printout of the suspension settings before and after. Car may be more twitchy the way they set it up. All alignments are not created equal.
Old Jul 31, 2005 | 04:58 PM
icy CL's Avatar
here are the specs before and after:
front -
left: (actual) (before) (specified range)
0.4 , 0.4 , -1.0 to 1.0 camber
2.5 , 2.5 , 1.8 to 3.8 caster
0.04 , -0.30 , -0.08 to 0.08 toe
right: (actual) (before) (specified range)
0.1 , 0.1 -1.0 to 1.0
2.3 , 2.3 , 1.8 to 3.8
0.05, 0.40, -0.08 to 0.08
rear -
left:
-0.08, -0.08, -1.0 to 0.0 camber
0.14, -0.18, 0.00 to 0.16 toe
right:
-1.1, -1.0, -1.0 to 0.0
0.14, 0.14, 0.00 to 0.16
i did question the rear right reading of -1.1 for camber and the mechanic said that it was ok.
Old Jul 31, 2005 | 05:17 PM
Allout's Avatar
Blown is Best
What you're feeling is the change in tow. As far as the right rear camber, it's borderline. You will see some inner tire wear at -1.1 on that corner. You may want to make sure you rotate religiously.
Old Jul 31, 2005 | 10:56 PM
icy CL's Avatar
thanks for the input, Allout. will make sure i take it back in a few weeks.
Old Aug 1, 2005 | 02:05 AM
Ssaba420's Avatar
u only got ur alinment done ? did u get ur self some new rubbers too ?
Old Aug 1, 2005 | 08:43 AM
icy CL's Avatar
no. just alignment.
Old Aug 1, 2005 | 08:46 AM
Zippee's Avatar
The change in toe will effect the way it drives as far as "darting" and steering response, but I don't see it effecting ride.
mlody
Dec 4, 2019 02:11 PM
emailnatec
29
Sep 28, 2018 04:27 PM
ceb
ILX
Sep 27, 2015 10:56 AM
kencepeda
Sep 26, 2015 05:13 PM
4drviper
Sep 23, 2015 07:42 PM
