Rotora slotted rotor update 35K miles
Old 11-07-2009, 09:03 AM
fuzzy02CLS's Avatar
Thought I give a brake update on this setup.
Rotated my tires this morning. Checked my brakes. Seems I'm going to need new front brakes. I had the Rotora setup on my car for 35K miles now. No warpage or other problems. Using satisfied ceramic pads. The rears look to be at about 50%.
The rotors look used however. The area the pads don't touch are heavily rusted looking. The slot cuts are even rusted looking. The rotor screws look like they may be a PITA to take out. I know it's normal & to be expected.
Going to see if my shop can cut the rotors. The guy is good & I seen him cut drilled rotors before. Then all I need is new pads.
Overall I am happy with the setup's performance.
Old 11-07-2009, 12:53 PM
Whats up with RDX owners?
civicdrivr's Avatar
Received 8,313 Likes on 4,897 Posts
Cool. Good luck with getting the rotors cut.
As far as the rotor screws go, I dont even use them. They serve no purpose.
Old 11-07-2009, 07:15 PM
Missing my
tnobori1's Avatar
Yeah, I have 45k miles on my Rotoras and they still haven't warped. To be honest, I was expecting a little, but I couldn't be happier with this brand! I'm putting on Akebono pads in a week.
Old 11-07-2009, 07:21 PM
wham bam thank you ma'am
Rajca's Avatar
got about 5k on my front drilled and slotted rotors. they way i drive, i have a few hot spots and heat cracks. got them from performance brakes or something like that. next rotors are gonna be rotora or a bbk. nto going with legend/nsx calipers anymore.
Old 11-07-2009, 09:51 PM
Rapture's Avatar
Good to hear. I was actually considering getting a set of Rotora slotted rotors when the brakes I have now start to go south. Any particular pad I should look into, either brand or material-wise?
Old 11-08-2009, 12:16 AM
Moodist's Avatar
I am not sure how this has happened but I have about 60k miles on my Rotora / Akebono pads. The car passed inspection 5 mos. ago also. I have not a clue on how this setup has lasted me so long.
Old 11-08-2009, 01:10 AM
I ♡ PEK PEK
n0rm's Avatar
It all depends on how you drive. The original brakes on my Mazda 3 lasted 94K miles. Whenever I took my car in for service, they give you the 5000 point inspection and my brakes were always marked green, 65% life remaining.
Old 11-08-2009, 07:07 AM
lowrd on tein CS biatch
CL-S progression 01's Avatar
to get the 2 screws off on the rotor is EASY as pie....
get a drill, set it on torque mod... get the PROPER sized bit. push really hard and then touch the drill trigger and you'll hear a lil snap (that's it coming loose). EASY breezy
Old 11-08-2009, 07:16 AM
k aren't rotora rotors like 4-500 easily??
why not just get urself some dba's?
they've been a life saver for my ride.
I bent the shyt out of my stock rotors, then my next set. and now these dba's are next level, IMHO
Oh and FYI, i've done brakes like 6 times on my car and every I used my drill on tq mode (slow mode in reverse) and those screws snap right off.
I I put them on with the drill in tq mode, so they are ON there hardcore. I'm sure any mechanic would do the exact same thing. NEVER use hand scre drivers for this as you will STRIP the screw usually. Drill is necessary for that initial quick thrust which you cannot get by hand which is what crack the screw loose. (this is where DeWalt really shines :-))
don't pay a dime!!! to do ur rotors.
If I did i'd be out 1000 already.
Old 11-08-2009, 02:19 PM
fuzzy02CLS's Avatar
I have an impact screwdriver for those not so nice screws
Old 11-08-2009, 02:48 PM
Rajca's Avatar
^same here
Old 11-08-2009, 03:27 PM
I think ppl assume "it's a screw" so they go at it with their hands and most of them come up short.
Old 11-09-2009, 07:23 PM
Former Sponsor
Excelerate's Avatar
ROTORA rotors are high quality rotors and they have been tested year after year by many AZ members. And 4 ROTORA rotors are less than 4 DBA rotors. I've checked pricing on both. DBA also makes a great rotor but ROTORA's rotors are good quality and reasonably priced.
Old 11-09-2009, 09:29 PM
K maybe the ones I wa looking at were different. cause I priced it out at 450 minimum with shipping. then taxes and duties..
dba's were $338.98 in my hands. <--- which was lower than i could find anywhere online.
dba doesn't make rears or else i'd get them... i went with ebc's
If these warp... i'll go to rotora, but so far i like them a lot... and they look GOOD too
Old 11-09-2009, 09:49 PM
I Wanna Beer
TheWeez's Avatar
Why bother with the rotor screws? They're always just a pain to deal with. They're only there to hold them on during assembly at the factory.
Old 11-10-2009, 07:27 AM
i just put everything back where it originally goes... everything.
like i said the screws are BUTTER if u got any sort of power tool and the right size bit.. (no right sized bit, you could create a nightmare by stripping the screw with a power tool and wrong size.)
that wouldn't be a fun one
mada51589
05-03-2022 08:54 PM
HOWELLiNC
10-19-2015 03:26 PM
HOWELLiNC
3G TL Photograph Gallery
24
10-08-2015 03:15 PM
HOWELLiNC
09-10-2015 01:39 PM
asahrts
09-04-2015 05:55 PM
Quick Reply: Rotora slotted rotor update 35K miles
