Rotor Screws Missing
Old Jun 25, 2011 | 06:24 PM
tr59210's Avatar
Hey guys, I am going to replace my rotors since they're going bad especially the passenger side rotor is loose right now, but the weird thing is that I can't find the rotor screws that the TL DIY calls to remove. I had my tires changed and so I looked at the rotors for the screws, but couldn't find them the holes aren't even there for the screws
any ideas?
Old Jun 25, 2011 | 06:30 PM
take pics?
Old Jun 25, 2011 | 06:34 PM
Zippee's Avatar
The screws are not really neded as the wheel and lugs hold the rotor in place.
See if the rotors will come off.
Old Jun 25, 2011 | 06:43 PM
RideCL's Avatar
From what i remember I had two on each one...but they are not ur typical screw and like Zippee said u dont really need them i guess.
Old Jun 25, 2011 | 06:50 PM
tr59210's Avatar
but the thing is, the holes aren't even present for the screws to go into... I wish i had taken pics
Old Jun 25, 2011 | 06:53 PM
tr59210's Avatar
it's like the rotors never came with the screws from the factory
Old Jun 25, 2011 | 07:15 PM
civicdrivr's Avatar
No big deal. The wheel and caliper holds the rotor on anyway.
Old Jun 25, 2011 | 07:30 PM
DarkSithCL's Avatar
Be Strong AND Courageous!
its all good....the screw is just there to hold the rotor on during the assembly process at the factory... the rotor screw guy was changing the bit on his drill when urs came by on the line...
Old Jun 26, 2011 | 01:06 AM
CH46ESeaKnight's Avatar
You may have some aftermarket rotors from the person who owned the car before you. Either way its no big deal. In fact you're lucky cause sometimes they are hard as hell to get off and ussually need a impact driver to get them off if they are oem.
Don't sweat it.
Old Jun 26, 2011 | 04:28 PM
tr59210's Avatar
they're supposed to look like these with the screw holes
but instead they look like these
Old Jun 26, 2011 | 08:31 PM
harvthesecond's Avatar
the two counter sunk screw holes are just for screws to hold the rotors in place during car assembly. The threaded screw holes are there to help you get a rotor free from the hub. Insert bolt of correct thread and tighten it until the rotor pops off the hub. Or do what I do and hit it with a BFH.
Old Jun 26, 2011 | 10:30 PM
aznboi2424's Avatar
I don't have screws on mine.
Old Jun 26, 2011 | 11:35 PM
Rejckt's Avatar
you're lucky you dont have the screws, they were a pain to get out. I didn't have an impact driver so I had to drill them out... and it wasn't a 5 minute thing.
Old Jun 27, 2011 | 11:36 AM
TheWeez's Avatar
I Wanna Beer
Werd. Drilled out the last set and didn't put them back. As others have said, they're only there for assembly at the plant and aren't needed. This is the first vehicle I've owned that's even had them.
Old Jun 30, 2011 | 04:20 PM
aznboi2424's Avatar
Yea, thats what happened to me, had to drill the fronts out. Went through a set of titanium coated bits too.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
tsx_boy
Dec 13, 2019 08:33 PM
gatrhumpy
19
Dec 31, 2015 04:22 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
