Which damn Plug to use??
Old Nov 1, 2010 | 12:59 PM
tr59210's Avatar
Angry Which damn Plug to use??
Which damn plug do I use for a 2003 CL type S?? O'reilly says one thing, autozone says another, NGKsparkplugs.com says another and NGK.com says another LOL!
Seriously though, I want to use the iridium IXs since they're a bit cheaper
O'reilly says to use:ZFR5FIX-11 #2477
Autozone says to use the laser iridiums(long life): IZFR6K11 #6994
NGKsparkplugs.com says to use the same as mentioned for autozone
NGK.com says to use: ZFR5FIX-11 #2477 (same as oreilly)
BUT, I found one more plug ZFR6FIX-11 #6441 which is one step colder than that which ngk.com specifies, but ngksparkplugs.com specifies the colder plug but a different model?
Any advice? I'm leaning towards the ZFR6FIX-11 #6441 which i'll most likely do once thanksgiving break hits and i'm out of school for a few days...
Old Nov 1, 2010 | 03:03 PM
Rapture's Avatar
I used IZFR6K11 #6994
Old Nov 1, 2010 | 07:13 PM
tr59210's Avatar
Thanks, I see that you went with the premium Iridium IXs which last about 100K miles, but have a premium price tag also..
I'll go with the regular Iridium IXs 6441 which last about 60K miles but half the price with the same heat range.
Thank for you input.
Old Nov 1, 2010 | 11:14 PM
504P_CLS's Avatar
For the Type-S, use the "6" heat range.
I'm running the 6FIX. 2 sets for the last 60-70k miles. Great value for money, works well.
Old Nov 2, 2010 | 03:07 PM
aznboi2424's Avatar
I used the lazer iridium plugs for 03 CL-S. My car's worth it, besides I dont wanna be touching that stuff for another 7 years.
Rapture's Avatar
The ones I actually went with were the Laser Iridiums, not Iridium IX's.
Old Nov 3, 2010 | 03:41 PM
CL-S progression 01's Avatar
lowrd on tein CS biatch
just replace them every 2-3 years... it makes a difference..
car will even start in one or 2 turns less.
did for me when I got my NGK Iridums. plus will increase mileage big time I can only assume. one of the reasons why I can get over 30mpg.
Old Nov 3, 2010 | 04:05 PM
tr59210's Avatar
are you talking about the iridium IX plug ZFR6FIX-11 part number 6441? Is that the one you used?
Old Nov 3, 2010 | 06:33 PM
I just went on excellerateperformance.com and searched for plugs there. code will be listed and just use that for a reference.
I believe you are referring to the correct part number.
Old Nov 3, 2010 | 06:38 PM
tr59210's Avatar
The plugs the have listed on their website are one step WARMER than the plugs, from what I understand, intended to go into our vehicles.
They have: ZFR5FIX-11 (One step Warmer Irid. IX)
While I Need: ZFR6FIX-11 (One step Cooler Irid. IX)
Old Nov 4, 2010 | 04:11 PM
Rapture's Avatar
alright well if you want those, then just buy them here:
http://ngk.com/results_cross.asp?pid...X-11&x=51&y=13
However according to the service manual, it says to use Laser Iridiums or Laser Platinums. When I did my spark plug change, the plugs that were installed (assuming from the factory) were Laser Platinums. PZFR6E or something like that.
Old Nov 4, 2010 | 04:47 PM
tr59210's Avatar
Thanks for all the help, but they sell them at autozone or O'reilly for 6.99, nearly a dollar cheaper. And it beats shipping charges and waiting for the plugs etc.
Old Nov 5, 2010 | 02:02 PM
Rapture's Avatar
Oh, I thought you were trying to figure out where to buy them.... my bad
Old Nov 5, 2010 | 04:14 PM
well i got 229whp without lazer plugs on my auto.. and over 30 mpg.
so my bet is that they say to get those plugs simply because they are more $ and last longer.. what DLR wouldn't want to do that.
Old Nov 6, 2010 | 05:09 PM
Rapture's Avatar
Yeah I got the laser iridiums since I kinda felt like getting Iridium IXs would be kind of a downgrade from the OEM plugs...
Old Nov 6, 2010 | 05:35 PM
i aint spending 2xs the cash just so they are "lazer" plugs.
w/e floats ur boat tho.
Old Nov 6, 2010 | 05:58 PM
Rapture's Avatar
Wait, you're not willing to buy plugs that match OEM quality because they're too much money, but you have no problem spending thousands more on a level 10 trans for your car? I'm not giving you crap for going the level 10 route, just think it's kind of ironic.
Old Nov 6, 2010 | 06:46 PM
typeR's Avatar
no ones doing the densos anymore ? IK20 or 22 to step em
Old Mar 27, 2011 | 05:54 PM
AARONSredTYPE-S's Avatar
I DID THE E3 PLUGS.
Great reviews across the board for them, so i installed the front three, and couldnt figure out what all needed to be removed from the rear, so i am going to finish it tomorrow. looks like just the IMRC needs to be removed..
The front only takes about 10 minutes, rears look to be about 50 minutes...lol
Old Mar 27, 2011 | 07:44 PM
did mine at night with a flashlight in about 45 mins
you need a swivel head for your 10mm socket and one long extension and one medium.
getting the bolt out was easy IMHO, it was getting it back in at night with the flashlight in my mouth that was the careful part.
don't drop that sucker
Old Jun 25, 2011 | 10:51 AM
SO, I was told today that I'm losing performance in my car because of my E3 plugs... This guy is a mechanic and owns a performance shop, but I dont see how he is correct..
He said NGK is the only plug to use on an Acura/Honda car...
what are your thoughts on this statement?
Old Jun 25, 2011 | 11:56 AM
Nersh7's Avatar
I Drive Like A Dick 8≈
Lol
I agree, heres what I found when I did research before I changed mine.
The denso and bosche plugs were just a much lesser quality in the plugs they make for honda's
The main difference between the different level of plugs is the life of the plug, obvioulsy the high end ones will last longer and the low end ones won't but performance wise I didn't find anything indicating that there was a difference.
When I do it again and if I were you I would go with the iridium tips.
Old Jun 25, 2011 | 09:01 PM
APPARENTLY, AFTER HOURS OF MORE RESEARCH, I F'D UP, BECAUSE E3 PLUGS ARENT GOOD FOR OUR CARS, OR ANY HONDA FOR THAT MATTER.
ONLY PLUG TO USE IN A 6SPD '03-'08 cl-s or tl
*NGK LASER IRIDIUM IZFR6K11*
now I gotta do this all over again, and spend $75 for the set of plugs as well
Old Jun 25, 2011 | 09:27 PM
Karanx7's Avatar
Unregistered Member
LOL, you should have checked with us over at the TL side.
The part number you want is: ZFR6FIX-11
Either the Laser Iridium or the Iridium IX is fine. The Iridium IX have been tried and tested by almost all the TL cars.
Old Jun 25, 2011 | 09:35 PM
ive been running the E3's for about 3k miles, and was comparing them to the old ones that were nasty and burned up in my car,(NGK), but I should have just stuck with the stock ones rather than try and do something different again. Im not having much luck doing that lately...lol..thanks Karanx
Old Jun 26, 2011 | 10:48 PM
aznboi2424's Avatar
Yea, I could have told you to stay away from E3 plugs.
Old Jun 28, 2011 | 09:46 PM
the part number you gave is the iridium ix, which on NGK website says it has the highest performance other than the race versions, so ill go with that..ordering tonight, and there was like 4 options if you google it, but only one on NGK website...i'll take your word on the tried and true...thanks man
Old Jun 30, 2011 | 04:19 PM
aznboi2424's Avatar
I use the lazer iridium plugs, the same ones that come with the car from the factory. Now those are tried and true.
Old Jun 30, 2011 | 05:11 PM
Karanx7's Avatar
Unregistered Member
No those aren't stock. The 3G TL cars used the Laser Iridium for stock, but our 2G TL and CL cars use NGK Platinums for stock. Most, if not all, TL guys get the Iridium IX.
The STOCK part number is: ZFR6F-11
The Iridium IX part number is: ZFR6FIX-11
Notice the only difference is the IX part.
Old Jun 30, 2011 | 05:39 PM
bought and installed new NGK iridium ix ZFR6FIX-11, and rest my ecu, and the car does run better after driving it a while. Amazing how plugs make a difference....Dont ever put anything other than NGK in a Honda motor, I now know from experience...thanks guys
Old Jun 30, 2011 | 05:50 PM
aznboi2424's Avatar
They used the lazer iridiums in the 03 CL-S 6spd. I also put them in my 01 without any issues. I consider them an "upgrade" from the lazer platniums. But the majority of the 2G CL/TL will run great on the lazer platniums. Also the IX probably wont last 105k.
Mike734
Dec 10, 2021 01:25 PM
ITSJESTER
17
Dec 6, 2018 02:29 AM
navtool.com
Sponsored Sales & Group Buys
87
Jan 23, 2016 01:25 PM
Joe Avesyan
Sep 29, 2015 03:57 PM
xsilverhawkx
Sep 28, 2015 06:51 PM
