Rotor replacement questions
Old Apr 16, 2011 | 12:41 PM
H's gray 03 CL type S's Avatar
I took my 03 CL-S to the dealer yesterday for an oil change and they gave me an estimate for $1100 to do the the brakes, alignment and change all the fluids which I thought was absurd. They want $375 for the front & $375 for the rear for new pads and to resurface the rotors plus $40 to rotate the tires when they'd already be off to do the brakes. Acura of Ocean is a rip off! I'm wondering if anyone knows of good rotors and pads that are cheap but not garbage. I figure I could just get new rotors & pads and do it myself for a lot cheaper so I'm asking for some recomandations on rotors and pads I dont care if there drilled, slotted, both or just standard vented. I dont wanna pay a ton of money but I also dont wanna put some of those garbage brakes on my car either its only got 44k miles on it. Any advice would be greatly appreciated.
Old Apr 16, 2011 | 12:57 PM
brian6speed's Avatar
Lone Wolf
Wow 1100 and they don't even give you new rotors. Highway robbery. I guess I am not surprised they get away with it.
For rotors and pads you can look on heeltoes or other sites. Ebc, hawk, etc.
Old Apr 16, 2011 | 02:01 PM
CL-S progression 01's Avatar
lowrd on tein CS biatch
i would be infuriated by that omfg
that is simply ludacris
Old Apr 17, 2011 | 02:14 PM
Any suggestions on a brand?
Old Apr 17, 2011 | 03:18 PM
civicdrivr's Avatar
I had good luck with Racing Brake rotors. I got them from Marcus at Heel Toe.
Old Apr 17, 2011 | 03:45 PM
DBA front, and ebc rear.... no problems now that i use hawk pads.
I ever so slightly developed a vibration from my cross drilled dba rotors cause the pads were not the best, i still have them in the garage and will put them back on once the slotted ones i have now wear out, but this time with hawk pads instead of the napa adaptive one pads they are called. one side is ceramic and the other is a composite of some sort. and one side wore out quicker than the other and the heat from braking created a vibration so i believe which is why i kept the rotors. and dba's cool down faster than any other oem replacement style rotor
Old Apr 17, 2011 | 04:30 PM
russianDude's Avatar
After having Brembo blanks, I decided to go with Centric rotors. I am pretty happy with them 15K miles after it, still did not warp...
Old Apr 17, 2011 | 08:23 PM
silvervtec96's Avatar
Back to a MT!
I have Racing Brake rotors and OEM pads.
mada51589
Jan 9, 2025 04:40 PM
wusty23jd
Sep 24, 2015 11:41 AM
asahrts
Sep 4, 2015 05:55 PM
nishant11
Sep 2, 2015 10:34 AM
