RL BBK Issue - Brake lines
Old Dec 17, 2013 | 07:52 PM
Palizboy's Avatar
Hey guys,
I have been reading up on the BBK process and I finally pulled the trigger. I put everything together but my car has been raised for a couple days now. I seemed to encounter problems with the brake lines. I finally was able to read up online hear and realized my SS lines were banjo hook ended and I need the bubble flared one the goes in direct without screws. The problem is I've been trying to find them online and can't. I found the following:
http://www.autoanything.com/brakes/75A4620A0A0.aspx
But the picture shows the same line I already have, the banjo hook one. Can someone please direct me to somewhere to get these. My car is currently inoperable and what really sucks balls is that I have been waiting over a year to do this project with all the part ready. I guess no matter how prepared you are you still end up behind sometimes.
Any help would be appreciated.
Gus
Old Dec 17, 2013 | 08:18 PM
AustinTaper's Avatar
Registered Member
http://www.amazon.com/gp/aw/d/B004VR...dsc_automotive
Old Dec 17, 2013 | 08:41 PM
Palizboy's Avatar
Thank you very much! Its been ordered and paid for 1 day shipping as well!! I needed this really bad!
Old Dec 24, 2013 | 04:42 PM
aznboi2424's Avatar
I have some Goodrich branded SS lines at home.
Old Jan 5, 2014 | 12:39 AM
Palizboy's Avatar
Everything is up and running now..it's surprisingly much more aggressive than I thought it would be. With a light foot you wouldn't feel it but slam it and the car stops dead in its tracks. I guess new tires helps! Although im hearing scraping noises while turning it's been a very good upgrade and I very much recommend it. I just gota lift it and see where all the ruckus is coming from!
Old Jan 5, 2014 | 04:57 PM
Brandon Allen's Avatar
2003 Acura CL-S6
I was about to order the SS brake lines but, just to make sure the ones in the link from the OP will work with the stock brake system, correct?
Old Jan 5, 2014 | 08:48 PM
Palizboy's Avatar
Yeah they will work but make sure to keep the hardware..turns out all I needed were some o rings but oh well..not mad because it actually fixed the problem
Old Jan 6, 2014 | 11:50 PM
2003 Acura CL-S6
Awesome thank you. I decided Im going to get the 95 Legend gs calipers also. I shouldn't have any issues with the SS lines should I?
Old Mar 11, 2014 | 06:28 PM
Rozay52410's Avatar
SS brake lines
I purchased SS brake lines for my 00 tl-s, and I have purchased RL front calipers and and all needed for the swap. The end of the brake lines don't connect to the calipers. I was wondering is there a type of way to connect it or I will just need to buy SS brake lines for the 06 RL calipers?
Old Mar 12, 2014 | 09:18 AM
CL-S progression 01's Avatar
lowrd on tein CS biatch
i got the SS russell lines on my CL... just with the stock brakes.
love them.
pedal is way more responsive in the beginning and shows no mercy when u tromp on it.
however best of all, the lines show ZERO signs of rusting on the exterior.
I bought ss lines before and they rusted out in 3 years and had to be replaced. so I am a huge advocate of russell..
mada51589
Jan 9, 2025 04:40 PM
yesSIR-S
May 13, 2016 05:42 PM
02tljj
Sep 11, 2015 12:37 PM
HOWELLiNC
Sep 10, 2015 01:39 PM
nuldabz
Sep 3, 2015 05:49 PM
