rim size help please
Subscribe
Jan 20, 2002 | 07:48 PM
will 18x7.5 (+37 +43 +48) fit on our cars?... which offset is right for me.. (lowered) and what series tires should i get.. i want thinner looking tires.. but i do not want it to rub since my car is lowered.. any help is appreciated
Reply 0
Jan 20, 2002 | 07:53 PM
you will be fine with a 48 offset.
none of the other offsets are good.
Reply 0
Jan 20, 2002 | 07:55 PM
Any suggestions on tire size? brands? ect..
Reply 0
Jan 20, 2002 | 08:06 PM
these are the rims im looking at...
volk racing gtp 18x7.5
or velox VX-5 19x7.5
Personally i like the silver or diamond cut look... but are there any other rims which are similar that any of you may reccomend??
Reply 0
Jan 20, 2002 | 08:41 PM
Yep....
A member had some custom 17x7.5" wheels made by HRE and they recommended +52 offset (they are custom wheels, so they recommend the "optimum" offset).
The closer you get to +52 in the 7.5" width the better (+48)
Reply 0
Jan 20, 2002 | 08:49 PM
Quote:
I like Toyos and S-03s for 3-season performance... IMO -- The Toyo T1S has the only acceptable load rating in a 225/40-18 (88 is too low, and most of the other brands you will find on TireRack will have the 88 rating in that tire)
If you move to non-XL rated tires, you can look at 225/45-18 (minimal rubbing issues) or check out the 235/40-18 tires (more rubber on the road, but potential for rubbing if you get a "wide" tire and lower the car a bunch). (The S-03s are relatively "wide"/"fat" tires!)
As a note -- there is a poor member who is removing his Toyo 235/45-17s on SSR Competition 17x8" +48 wheels for 225/45-17 Toyos (he has Comptech springs with Koni shocks and he has not had an easy time of it). He was having serious rub problems with that combo (where others without the Konis where fine -- go figure...)
Ooops -- I checked and the Nitto-555 in a 225/40-18 supports a 92 load rating
Reply 0
Jan 20, 2002 | 09:15 PM
I've got 18 x 7.5 wheels with 42 offset and Eibach springs.
Running 225 40 18 rubber on them.
Did get some rubbing in the back and had to roll part of the fender lip to stop it. Wasn't a big deal, but had to be done.
Reply 0
Jan 20, 2002 | 09:22 PM
The S-02s are also "wide" tires.
They are great tires -- do watch the 130 MPH runs with 4-people in the desert (with the 88 SL load rating they have)...
Reply 0
Jan 20, 2002 | 10:12 PM
Reply 0
Jan 20, 2002 | 10:14 PM
Eric:
Your email's contained nothing.....wierd...anyhoo, I haven't heard from Dwight either.
Keep me posted ! Sorry about the email confusion..
Reply 0
Jan 21, 2002 | 01:31 AM
Quote:
Originally posted by Fabvsix
Eric:
Well, that was the topic... Wondered if you heard from him...
I did clean out my PM inbox, but you should have gotten something in the "message" I sent to you!
-Thanks
Reply 0
Subscribe
