Revs climb when I press in clutch...
Flying High Delta Pilot
Is this a usual thing. If im just cruising along in 6th..and i press the clutch to downshift..the revs can climg as high as 1000k rpms before they fall. I know our cars have a Dual Mass Flywheel? So i dont know if thats what it does. My revs started climbing in my S2000 just before a traded it in. Ended up being a bad Pressure Plate. I had a Toda lightweight flywheel in that ...so ..i dont know if this is different. Doesnt matter what gear im in..if i press the clutch..its almost as if i still have the gas down for a second. And the weird thing is..the clutch isnt slipping on the upshifts. IM stumpd and so is acura. There isnt a newer clutch..so they told me just to wait..get an aftermarket on..and they'd put it in free of charge...now thats Acura Customer Service.
Desmond
03 Acura CL-S 6spd
Desmond
03 Acura CL-S 6spd
im back
it does it on mine also, it also does it on my friends wrx..try this.....take your foot completely off the gas and press the clutch the rpms will just fall trust me
mine will fall if i completely take my foot off the gas..but you know what. On my S i also had a bad throttle body during this phenomenon. They told me they usually replace alot of accord tb's for some odd reason they go bad..i hope this is NOT the case in or cars.
Received 7,054 Likes
![Stupid](https://acurazine.com/forums/images/smilies/imwithstupid.gif)
I believe the DUAL MASS FLYWHEEL reduces the vibration for the manual transmission..it's literally "vibration-free". Just put your hand on the stick while idle...u'll notice there's no shaking like on an integra w/manual tranny.
As for the RPM climbing issue, mine does that too. It's not a big deal...it's just sometimes I depress the clutch too quickly and probably not quick enough on the gas...it's minor..even 1k rpm higher before dropping...
I don't think u should worry about it...
Re: Revs climb when I press in clutch...
![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
Actually it is probably the action of the IAT not adjusting quickly enough. By engaging the clutch you remove the load from the engine. The ECU probably has the IAT opened which, without load, could provide enough air into the engine to allow it to rev. The ECU then starts closing the IAT which then drops the revs.
Just normal operation.
Desmond
03 Acura CL-S 6spd
Desmond
03 Acura CL-S 6spd
1) emissions, or
2) holds the throttle open a bit for a smoother shift into the next gear.
soupi
14
11-15-2015 11:15 AM
