Revised E-Manage 5AT Harness
Some of you may be aware of the problem which was experienced with the 5AT harnesses I recently sent with the IC kits. Both appear to have failed. I beleive it revolved around the simple soldering of wires to straight pins on the socket base. This was supplied this way to me and is counter to how I made mine, allmotor and BlueCLS6 6MT harnesses. But to expedite and keep costs lower I used another supplier.
I can't completely fault them as they have made similar harneeses without failure. I just feel it is to fragile for continuous duty. So I revised the harness to focus in on supporting the seemingly fragile area.
The current harness has an aluminum brace for the socket side pins along with a shroud. This should support the pins as needed and protect them from damage.
i wish all these companies (:cough:unichip, stone racing, obx) would be more like scalbert. they troubleshoot problems asap and take care of the customer. they actually TRY to work shit out.
so scalbert, what are the plans for hope system's now that you are selling the car and moving on to other things?
i wish all these companies (:cough:unichip....
I could but I won't...
Looks great Steve. I don't think the Hope System's IC kit will still be around by the time i'd have the cash flow for it. Good luck and again, that looks great.
Originally Posted by mrsteve
Would I see gains using the E-Manage w/o the IC kit?
Conceptually yes, but I never got a chance to fully test it. I suspect it could be used to make some decent gains similar to the Unichip, maybe better, maybe worse.
I never got a chance to test the latest ideas on an NA car.
Originally Posted by ghost_masterCL
any way to make the e-manage hook up to a 3.0CL? Orwould I just find one for the honda accord 3.0 engine?
Originally Posted by darrinb
i do brad?? or did u want one on a s/c car??
Originally Posted by ModAddict
Does anyone have any dyno's showing the A/F ratio,... I looked in the dyno section but only saw one with an aparrent IMRC problem.
Yes, do you want me to post?
xsilverhawkx
09-28-2015 06:51 PM
