Replacing Brakes
Replacing Brakes
Ok so am waiting to get my brakes from Exelerate and then I will be replacing them my self (with some help) soon. I am not that knowlegable on cars and have never done this. I can't seem to find a do it yourself on the brakes and rotors for the second gen cl. So any help or advise will be appreciated.
I'm Cool
are you just replacing the pads? or both the pads and the rotors? Heres a DIY found on Google (most cars are similar when it comes to changing brake components)
http://www.automedia.com/Replacing/B...cr20050701bp/1
HTML Code:
https://acurazine.com/forums/showthread.php?t=186243&highlight=brakes
I'm sure a search on "rotors" will turn up plenty of help on swapping them out.
I am doing the rotors and will do a search on that and see what I come up with. i have been told it is pretty easy, I just want to make sure I have the best idea as to what I am doing before I do it.
thanks for the help
thanks for the help
Hardest part are the screws that hold the rotors on. You'll likely need a light touch & heavy hand or an impact screwdriver to get them off without striping them & having to drill them out.
2nd hardest are the caliper bolts. Sometimes they can be really tight.
After that it's cake.
Registered User
Replace Brake Pads
http://www.cardomain.com/ride/184466/24
Replace Rotors
http://www.cardomain.com/ride/184466/23
Replace Rotors
Former Sponsor
Make sure you break in the new setup properly. Speed up to about 60 mph and slow down to about 10 mph starting with light pressure and moving up to moderate pressure by about the 8th time. Allow the brakes to cool. Be easy on the brakes for the first few hundred miles. No hard braking; try not to engage ABS. And no 120mph-0 stops. Obviously if you have to stop you stop but you risk damaging the rotors.
![Bow](https://acurazine.com/forums/images/smilies/bow.gif)
Originally Posted by Blazin_TL
Replace Brake Pads
Replace Rotors
Replace Rotors
mada51589
05-03-2022 08:54 PM
asahrts
09-04-2015 05:55 PM
