Rajca's Project CL-S6 Car
Old 12-11-2009, 10:19 AM
  #521
3.7L Nitrous Breathing CL
richardparker's Avatar
^ very true
Old 12-11-2009, 11:55 AM
  #522
Whats up with RDX owners?
civicdrivr's Avatar
Received 8,391 Likes on 4,937 Posts
Originally Posted by phee
i gotta chime in here.
i see all this certain amount of psi will yield certain amount of power and i have to point out that turbo size matters in these equations.
28 psi on an 18g isnt the same as 28 psi on a GT35
THANKYOU!
Rajca is planning on running a ginormous turbo.
Its possible that it may be too big for the motor though, so it may have a hard time staying in boost.
I remember what CL hes talking about though, the one in the 400s. It was a silver 03 IIRC, a guy that worked for Greddy at the time built it (hes a member here).
Actually, I have the magazine article:
http://www.turbomagazine.com/feature...g35_turbo.html
Old 12-11-2009, 01:17 PM
  #523
B:
MoneyPit's Avatar
^^thanks for the link, I hadn't seen that before.
Regarding the turbo application, c'mon people. It's obvious that we're all assuming the chosen turbo is going to be optimal efficiency for the chosen application. There's a reason there are turbo efficiency maps for different turbo specs for different applications...
Rajca, also keep in mind that these numbers are 6psi @ 10.5:1 compression. If you plan on lowering compression, you'll have to boost a ton more to reach similar numbers.
Old 12-11-2009, 03:11 PM
  #524
wham bam thank you ma'am
Rajca's Avatar
I know. Gonna go 9.5:1 cr.
Old 12-11-2009, 03:48 PM
  #525
B A N N E D
friesm2000's Avatar
Originally Posted by Rajca
from what i can remember their were two ppl that were pushing over 400whp. one 468whp or something like that on 10-12psi. its blurry bc i dont know the exact specs but stock motor. theirs a spring and retainer clip set out their already. need to make custom valves and dont know what im gonna do with cams.
one way or another, im gonna hit my goal. weather its more boost or more spray.
try looking into some mdx cams, i know they are different but not quite sure if in a good or bad way
try some nitro-methane fuel (like they use in top-fuel dragsters), that will produce some extra power, while draining your pockets
yeah depends on the flow rate of the turbo itself, and also how hot it actually makes the air when it boosts it to a certian level
also it is a whole lot easier to run higher boost with high compression, when you are not limited by pump gas
Old 12-11-2009, 04:28 PM
  #526
I got the Shifts
phee's Avatar
lower compression with higher boost will yield more power than high compression with lower boost.
Old 12-11-2009, 04:35 PM
  #527
B A N N E D
friesm2000's Avatar
then you lose your low end torque (not really a concern for rajca though being a track car),
but i was just saying it is alot easier to run whatever compression with whatever boost you want when you are not limited to pump gas
Old 12-11-2009, 05:20 PM
  #528
civicdrivr's Avatar
High comp plus boost = detonation issues
The loss of low end torque is true when you have a low comp NA motor, but boosted you'll make more power anyway, and safely.
Old 12-11-2009, 05:41 PM
  #529
B A N N E D
friesm2000's Avatar
better gas can fix the detonation issues, there is actually a gas station only like a couple of miles from me that sells 100 octane street legal gas, but good luck filling up any other place within 100 miles or so (or trying to go on a road trip)
but the turbo will spool up faster with a higher CR ratio, so you have a broader/wider powerband, which is really nice and kinda neccesary for a street car (for driveability) (should also be better MPG too)
and yeah a low cr will let you make more power, but that power will geaneally be peakier (upper RPM's so not as usable on the street), but for rajca and it being a track car, it does not really matter, cause he will proably be staying in the upper powerband anyways
Old 12-11-2009, 06:24 PM
  #530
Rajca's Avatar
^yup. its gonna be a STREET legal track car.
Old 12-11-2009, 06:56 PM
  #531
civicdrivr's Avatar
Yea, but the grade of gas varies too much to run high comp on a turbo motor safely, even if it is built. Pump gas at one station can be a certain octane one week, but the next week could be slightly different at the same place.
If you want the turbo to spool quicker, get a smaller turbo. Hell, build a hybrid snail (smaller hot side, larger cold side). Dont sacrifice reliability and depend heavily on pump gas. Its not worth the possible outcome.
Old 12-11-2009, 07:02 PM
  #532
Rajca's Avatar
i actually want some lag. seen youtube videos on my turbo on bmw and subies, and what not. turbo spools around 3.5-4k and u can hear and feel the pull at that rpm. now add some spray and its a diff story
Old 12-11-2009, 07:06 PM
  #533
B A N N E D
friesm2000's Avatar
never heard that term before , but yeah you mean like a t3/t4 turbo (just as an example)
or hell even a variable geometry turbo (if we could even control the F***er like a factory car does, not saying the aftermarket could't just be quite a bit of work to get it to work right)(and have enough options in the actually size of it)
Old 12-11-2009, 07:20 PM
  #534
I got the Shifts
phee's Avatar
its not like these cars have much to begin with.
plus the loss of power isnt very noticable wth these cars after a snail is installed. even part boost will more than make up for it
Old 12-13-2009, 10:24 PM
  #535
nf3d0149ab's Avatar
Car is coming along...glad to see you to still updating the thread.
Some good info.
Old 12-13-2009, 10:54 PM
  #536
B A N N E D
friesm2000's Avatar
i liked you old avatar better
Old 01-05-2010, 09:01 PM
  #537
Rajca's Avatar
keeping the tread alive. been working my ass of at my work. just to get the build going and paying off my school loan.
but anyway. but a few more parts made by p2r and got the shifter bushing. now im gonna make some custom ss clutch lines at work. im gonna get the ones with the black rubber on the outside bc im trying to make it as sleeper and possible (yes i know, ppl will see the turbo). but still. want little to no bling under the hood.
Old 01-05-2010, 09:09 PM
  #538
civicdrivr's Avatar
Dont go crazy with the clutch lines. The hardlines are better. Just replace the rubber lines on it.
Old 01-05-2010, 09:11 PM
  #539
Rajca's Avatar
im leaving the hard lines alone. just getting rid of the rubber ones.
Old 01-05-2010, 09:12 PM
  #540
B A N N E D
friesm2000's Avatar
i have seen a ss clutch line before somewhere, so you can just buy one, but yeah be easier just to make it yourself, and not have to pay for it ethier
and for civic, i think he might just be replacing the rubber line, and leaving the rest of the hard line intact
  #541
civicdrivr's Avatar
Ok.
It honestly doesnt matter if you use silver or black, you cant even see the line when you pop the hood.
Old 01-05-2010, 09:19 PM
  #542
Rajca's Avatar
ive seen them on here also. but i can do it for free at work. then why not. might do some rear ss brake lines also.
Old 01-05-2010, 09:24 PM
  #543
B A N N E D
friesm2000's Avatar
as i said
Old 01-05-2010, 09:25 PM
  #544
Rajca's Avatar
anyway, need to fix my lip kit a bit, paint it, and them make a cf front diffuser for it
Old 01-05-2010, 11:09 PM
  #545
I got the Shifts
phee's Avatar
my girlfriend didnt she was like "that aint me!"
Old 01-05-2010, 11:17 PM
  #546
B A N N E D
friesm2000's Avatar
you cold always pm them to me and i will post the then
Old 01-07-2010, 08:05 PM
  #547
Rajca's Avatar
keeping the thread alive (some what)
have to figure out how to make the filter fit. lol
and it wont be internal waste gate. thats getting blocked off
Old 01-07-2010, 08:09 PM
  #548
civicdrivr's Avatar
I LOVE THAT RUG!!!!
I used to play on that with my hot wheels cars when I was a kid.
Ok, ok, I still do.
Old 01-07-2010, 08:26 PM
  #549
I want one.
What's that a 10-11" filter ?
  #550
03 Boosted CLS
cb717cls's Avatar
I LOVE THAT RUG!!!!
Ok, ok, I still do.
LOL
Old 01-07-2010, 08:27 PM
  #551
StreetKA's Avatar
in Europe we have 98 octane gas on every station and shell has V-power that has 102 or 103 octane
Old 01-07-2010, 08:34 PM
  #552
Rajca's Avatar
9" long, 4" inlet, 5" base
K&N ftw
Old 01-07-2010, 08:39 PM
  #553
B A N N E D
friesm2000's Avatar
, but your avatar says NJ
but yeah alot of other places around the world have higher octane then us
Old 01-07-2010, 08:46 PM
  #554
civicdrivr's Avatar
Apparently you've never seen Jersey Shore. They clearly arent American. They dont even speak English.
Old 01-07-2010, 08:54 PM
  #555
StreetKA's Avatar
i am an emigrant do you have problem with that ? im here since 2007 and i have GC
Old 01-07-2010, 08:59 PM
  #556
I got the Shifts
phee's Avatar
^they are just making fun of guidos. not you man. its all love
Old 01-07-2010, 09:00 PM
  #557
civicdrivr's Avatar
Dude, it was a joke. A joke not meant towards you. It was directed at those on the Jersey Shore.
And look around this country, every one that isnt living on an Indian Reservation is an immigrant in some way or another.
  #558
Rajca's Avatar
also
drilled the holes for the nitrous foggers, gonna tap them tomorrow and put in the foggers. then put the spacer on my spare engine and start mocking up the lines
Old 01-07-2010, 09:02 PM
  #559
civicdrivr's Avatar
Precisely
  #560
StreetKA's Avatar
yup
Quick Reply: Rajca's Project CL-S6 Car
