Quick question
Old Jan 24, 2007 | 04:36 PM
Sloth32's Avatar
Quick question
I am in the need to replace my front rotors and front and rear brakes. What I am wondering is should I go ahead and replace the rear rotors also or is there no need???
Please respond
Old Jan 24, 2007 | 04:42 PM
gaping46and2's Avatar
SOLD: 03 SSM CLS Auto
Not unless they are worn. Most likely all you'd need to do is turn the rotors and replace the pads for the rear. Unless you are wanting to get aftermarket rotors for the rear (slotted/cross drilled).
Old Jan 24, 2007 | 04:47 PM
Sloth32's Avatar
If i order I am getteng slotted for the front
Old Jan 24, 2007 | 04:53 PM
Just depends on what you're going for. Are the rear rotors worn out, have they ever been turned, are they warped? If not, they most likely do not need to be replaced. Though, rear slotted will match up with the front slotted, but not entirely necessary.
Old Jan 24, 2007 | 04:59 PM
Sloth32's Avatar
I have read that if the rotors are warped they will warp the pads
Old Jan 24, 2007 | 05:25 PM
If the rotors are warped, the pads will need to be replaced, and either the rotors will need to be turned if possible, or replaced.
Old Jan 24, 2007 | 05:29 PM
Sloth32's Avatar
Thanks for the help I guess I will order just the pads and try and turn them if they can be. Doing the work my self for the first time. Just hope I don't f*#k it up to bad
Old Jan 25, 2007 | 10:29 AM
SuperTrooper169's Avatar
In the Mid-South meow
That's scary. Brakes are not something to hope you don't f*ck up. They're pretty easy but if you do f*ck them up you'll be f*cking yourself up more when you crash.
Rdub81
ILX Photograph Gallery
Mar 17, 2016 03:02 PM
06TLMatt
Oct 2, 2015 08:14 PM
Strath
Sep 27, 2015 11:53 PM
HOWELLiNC
Sep 20, 2015 04:21 PM
datadr
Sep 12, 2015 09:12 PM
