quick little convienant mod
So i did the vsa delete a while back successfilly and always wanted to figure out a way to have the traction control switch turned off when you start the car. Well i did this, sorta. I wired a seat belt wire to the vsa switch soo when you plug in your seat belt, it turns off traction control...i know, kinda half assed but i am satisfied. Under the driver seat there is a blue/red wire in the center of the clip i ran a wire from there to the wire connecting to the vsa switch that is orange / whie i believe. I will provide pics if anyone is interested....
Yes as soon as you buckle your seat belt it turns it off......you can also make a 555 monostable timer which, is complicated but would be the correct way to do it. The vsa switch when you push it it sends a signal to the orange/white wire it doesnt connect a circuit.
Im not positive if you are understanding whatt i did correctly....this isnt to shut off the tcs light or the vsa light.....this makes it so when you plug in the seat belt its basically like pushing the vsa button to turn the traction control off.
And what a 555 monostable timer does is it gets an electrical signal when you start the car waits a few seconds and then sends an electric pulse out. Which is exactly what that slp unit is for firebirds/camaros which makes the traction control off when you start the car.
I've deleted the vsa and have a tcs light on my dash now.
I want that gone.
After re reading your stuff it seams like you are only using the seat belt setup because your arm is to short to reach the switch
I want that gone.
Oh...i wouldnt know.where to begin to help you. the lights probably just on because theres no vsa unit. If theres no problems with your car when you spin your wheels id say just pull the bulb out of the cluster if it bothers you.
Got some plans with the auto gearing.
any codes show up from doing this ?
InFaMouSLink
Oct 27, 2015 06:52 PM
My auto shop teacher said that he used to put a piece of black tape over the seatbelt light.
