quick little convienant mod
So i did the vsa delete a while back successfilly and always wanted to figure out a way to have the traction control switch turned off when you start the car. Well i did this, sorta. I wired a seat belt wire to the vsa switch soo when you plug in your seat belt, it turns off traction control...i know, kinda half assed but i am satisfied. Under the driver seat there is a blue/red wire in the center of the clip i ran a wire from there to the wire connecting to the vsa switch that is orange / whie i believe. I will provide pics if anyone is interested....
lol
Hey it works...and it makes me wear my seat belt more often lmao
So this shuts off the tcs light ?
Yes as soon as you buckle your seat belt it turns it off......you can also make a 555 monostable timer which, is complicated but would be the correct way to do it. The vsa switch when you push it it sends a signal to the orange/white wire it doesnt connect a circuit.
Are you sure you can turn off the dash tcs light off with just the switch ?
How could I wire it so I would never see it ? None of my seat belt wiring is connected. |
Im not positive if you are understanding whatt i did correctly....this isnt to shut off the tcs light or the vsa light.....this makes it so when you plug in the seat belt its basically like pushing the vsa button to turn the traction control off.
Wait maybe im not understanding you lol
And what a 555 monostable timer does is it gets an electrical signal when you start the car waits a few seconds and then sends an electric pulse out. Which is exactly what that slp unit is for firebirds/camaros which makes the traction control off when you start the car.
I've deleted the vsa and have a tcs light on my dash now.
I want that gone. After re reading your stuff it seams like you are only using the seat belt setup because your arm is to short to reach the switch |
Did you put the resistors on the wiring harnes where they clip into the vsa throttle body unit?
I don't even have that,I'm using the base harness with the type s ecu.
Oh...i wouldnt know.where to begin to help you. the lights probably just on because theres no vsa unit. If theres no problems with your car when you spin your wheels id say just pull the bulb out of the cluster if it bothers you.
Originally Posted by richardparker
(Post 13713727)
if u never wanna see the light just pull out the cluster and remove the bulb.
Ive found the easiest way to disable TCS/VSA is to buy a 6MT. :teef:
Originally Posted by typeR
(Post 13713996)
you're gonna need to figure that out ... who knows what that ECU is doin because it sees no VSA present then worse what happens when it tries to stop wheel spin but cant
(Post 13714820)
Got some plans with the auto gearing.
Originally Posted by CL-S progression 01
(Post 13714588)
Why would a CEL pop up for removing a light bulb?
:werd: My auto shop teacher said that he used to put a piece of black tape over the seatbelt light.
The OP's thread title doesn't lie, this truely is a convenience mod. |
