Question for those with air tools
Spectacular Aroma About
Hey Guys,
Well Santa brought me a 6hp 33gal Craftsman air compressor for xmas.
Now I need to get me some air tools. I was thinking about getting a cheapo combo set but I'm never happy with anything cheap. I'd actually like to get an Ingersol Rand Titanium impact. (1000lb ft weighs less than 4lbs). They're about $200 though and I can get a decent impact and ratchet for less than $100. Hate to not get the badass one though. I've never owned an impact and I was wondering if any of them can be turned down so you can spin bolts on without overtorqueing them? I use my cordless drill for this and really like it. Can the air pressure just be turned down for tightening? What air tools are good to have?
I'm seriously considering this kit: Mechanic's Air Tool Kit
This one seems too cheap:
Starter Air Tooll Kit
Here is the bad boy:Titanium Impact
I'm leaning towards getting the Titanium impact and picking up a ratchet later. Anyone know what would be a comperable ratchet to this impact? What do you guys think? Any thoughts on this would be appreciated.
IR is a very good brand for airtools. convienent because its available through dealers and not just restricted to the tool truck. the impact gun has a torque adjuster on it, but i wouldn't use it on anything thats too fragile, leave that to the air ratch or hand tools!
Unless you are doing work several times a week the Craftsman air tools are more than adequate. I have been using my Craftsman tools with my cars since '95 and still on the original set. They have performed hundreds of hours or trouble free service.
To very the applied torque, the easiest way is to low the pressure through the compressor's regulator.
i like snap-on, and mac but then again i really havent had much experience with any others. you kinda get what you pay for with these kind of things, i would say go with the better one now cause if you take care of it, it will last forever
I sell air tools and other related equipment for a living. I would recommend IR's 2131. It is light, quiet but very powerful. Four torque settings are available. Comes with a two year warranty, but I like them because they never come back. The air hose inlet has a built in swivel, and since the body of the tool is high impact plastic (unbreakable) it is never cold or hot to handle, as opposed to a steel tool. Even the air outlet is located at the bottom of the handle instead of the nose. This means that when you do that set of lug nuts on that break dust covered wheel, the dust doesn't blow back in your face, same goes when you do a nut in an rusty or dirty area. Hope this helps. As for the best ratchet, IR's 1107 is the way to go; it recently replaced the old tried and true 107. These might be overkill somewhat for home use as Scalbert says, but if are seeking the best VALUE, these would be my choices.
Thanks for the advise guys! I just ordered a IR 2135ti (the titanium one shown above). I had been watching it on ebay and realized that 24 were already sold ond only one was left so I went for it. $195 shipped brand new. It's way overkill for me but I like the light weight and the fact that it will probably handle anything I can throw at it. I'm sure I'll be glad I have it when it comes time for sways and headers. Now to find a ratchet. ChucksTL, I'll have a look at the IR 1107. Thanks.
I pretty much got the same thing from Santa. Except, I got the 30 gal. vertical. Mine came with a tool kit. It had a quick connect with a few male/female connectors and a hose. It also has an impact, ratchet and hammer. You may want to look into this because yours should have came with it, unless they were out. Check out these links.
If I am thinking right, this should be yours.
http://www.sears.com/sr/javasr/produ...id=00916556000
Here is the one that I got.
http://www.sears.com/sr/javasr/produ...id=00916555000
Believe it or not, but you actullay save money if you get it with the tools. Here is my exact compressor w/o the tolls.
http://www.sears.com/sr/javasr/produ...id=00916731000
Yeah I saw that. The one I got is a horizontal with an oil free pump. I'm not sure exactly what the significance of that is but the ones without the kit are both oil free. You try out your tools yet? I can't wait. My brother-in-law who got me the compressor will be bringing it down soon.
-S namyaC-
I have a 6HP 30 Gallon horizontal unit but mine is loud as crap. So I put it in the basement in a utility room which is isloated by another unused room. I then ran the air hose up through a hole into the garage. So now all I have is a coiled up hose and a noise free work space.
Both of the compressors are the same. I thouhgt the same as you, but they are both oil free. It is just the way that the write up that sale. I would go back for the tools. Again, the compressors are exactly the same.
I have not had a chance to use any of the tools yet.
Mine is also pretty loud. But, i can live with it.
Go get you FREE tools.
Someday pigs WILL fly!
I have one as well. A few tips, cheap tools last about 2 years. The air has moisture init so get a bowl filter to take the water out. It's impossible NOT to have water in it. It is a by-product of pressurization. Make sure you drain the tank as well every once in awhile. You would be surprised how much moisture gathers in the bottom of the tank. Get an in-line oiler as well. Makes the tools last longer. My first set was a $80 combo from All-Trade at Costco. Lasted about a year or so. Trigger stopped working and I am sure it was lack of oiling that caused it or moisture, or a cobination of the two.
Find beauty in dissonance
Can compressors be switched 'ON' and loaded all the time? Or should the pressure be released when not in use?
I can't find the
for mine. I turn it off and let the air out when done. The noise is bad in the garage. I was going to move it to the basement, like scalbert. Mount a hose real on the wall, save a lot of space.
I can't find the
![rtfm](https://acurazine.com/forums/images/smilies/rtfm.gif)
Mine has been on constantly for 25 years. Just make sure your system does not have any leaks. And you'll need several impacts / wrenches.
3/8 air ratchet is handy, 1/2 impact for big work, 3/8 butterfly impact for small work, die grinder for making sparks, paint gun, nozzles for cleaning carbs, sand blaster, DA sander.
My IR compressor is a big ole V twin model, 2 stage. It is the oil type but is cast iron and is probably 50 years old, but still works flawlessly. That is the advantage of the industrial duty style compressors. The oil free's aren't designed for as heavy of use, but will work fine for the home owner.
I keep my compressor plugged in and pressurized, but I keep the power switch off so it doesn’t come on unexpectedly and scare the CRAP out of me.
When I use it, I flip the switch on, when I’m done, I turn it off.
I have a ball valve just before the line up to the hose reel so I can turn the air off there and bleed the line..
Here’s my setup……
Here’s my setup……
![](http://photos.imageevent.com/shawnsef/miscstuff//IMG_1149.jpg)
Here’s my patented “HOSE-WATER-BLOWER-OUTER-THINGER” device. ![Big Grin](https://acurazine.com/forums/images/smilies/biggrin.gif)
I screw it onto the end of my 100FT garden hose reel when I’m done washing the car in the winter.
Then I use the compressor to BLAST all the water out so it doesn’t freeze in there.
![](http://photos.imageevent.com/shawnsef/miscstuff//IMG_1149a.jpg)
Bleed Honda Blue
Ask any professional mechanic which brand of air tools are the best or which brand of air tools they own. I would bet 8 out of 10 would say Ingersoll rand. I think Snap on air tools are the worst.
Sweet as Gold
Re: Question for those with air tools
Hey Guys,
Hey Guys,
Sweet as Gold
-S namyaC-
IR is good stuff, they make kick ass compressors but Snap-On owns the tools.
Craftsman is pretty good too, but they are't Snap-On. I use them b/c it's more convienent for me to just jet down to Sears for something. If I used them day in/day out - I might have a diff opinon.
Bleed Honda Blue
Re: Re: Question for those with air tools
. If your gonna buy craftsman...get the professional series w/ the black handle...thats my second impact gun.
Just wondering, isn't that craftsman professional series with black handle and chrome front made by Ingersoll Rand?
Originally posted by Shawn S
Here’s my patented “HOSE-WATER-BLOWER-OUTER-THINGER” device.![Big Grin](https://acurazine.com/forums/images/smilies/biggrin.gif)
![Bow](https://acurazine.com/forums/images/smilies/bow.gif)
![Boink](https://acurazine.com/forums/images/smilies/boink.gif)
![King Grin](https://acurazine.com/forums/images/smilies/kinggrin.gif)
![Pimp Grin](https://acurazine.com/forums/images/smilies/pimpgrin.gif)
![rofl](https://acurazine.com/forums/images/smilies/rofl.gif)
![Jump](https://acurazine.com/forums/images/smilies/jump.gif)
![Butt Head](https://acurazine.com/forums/images/smilies/butthead.gif)
![Excited](https://acurazine.com/forums/images/smilies/excited.gif)
![Shake](https://acurazine.com/forums/images/smilies/shake.gif)
![Moon](https://acurazine.com/forums/images/smilies/moon.gif)
![what](https://acurazine.com/forums/images/smilies/what.gif)
![Clap](https://acurazine.com/forums/images/smilies/clap.gif)
![Flash](https://acurazine.com/forums/images/smilies/flash.gif)
![Canada](https://acurazine.com/forums/images/smilies/canada.gif)
![KeKe](https://acurazine.com/forums/images/smilies/keke.gif)
![Rock On](https://acurazine.com/forums/images/smilies/rockon.gif)
And that about says it all!
Originally posted by Bluto
Where did you get the reel? I'm trying to find a good deal on one. How about the extra fittings a pieces to connect it to the compressor? Thanks.
The ball valve & other fittings I got at Home Depot.
Not including the 50FT HOSE, which I already had, I think it was only about 40 dollars or so for everything.
It works great too.
Sweet as Gold
Re: Re: Re: Question for those with air tools
Got BOOST????
I just bought both 1/2 and 3/8 titainum ones. I like them alot. Snapon are great tools, but way over priced for a homeowner. You don't need that type of quality for not using them every day. I also bought a angle grinder with a 3m roloc disc. Works good for removing old gaskets and ruffen up your rotors. A air blower is a must too also. I like to use a cutoff wheel, but i use my 120v grinder w/ a cut off disc instead so i have a constant spin.
Originally posted by Ant7701
OK...don't buy thr IR w/ 1000ft lbs...cause it's not. Our tool guy at work let us borrow one for a week..the friggin thing did no better than my Snap-on rated at 650 or anyone elses guns rated between 500-650. It looks nice and sounds mean while using but just get the regular IR gun rated at 500 or 550.
Sweet as Gold
Ohh...you'll be more than happy w/ the gun...it's excellent. I was just trying to stop you from buying it solely because it was 1000ft lbs. There's alot of hype about this gun but until u do some real world shop testing you won't see what I mean. But like i said it's a great gun and you'll have no problems doin work at ur house.
cycdaniel
12-17-2019 10:58 AM
