Question on spring install?
Is it necessary to remove the back lid where the speakers sit to install the rear comptech springs on a CL-S 6 spd? Need quick answer because dealer is wants to charge more than what was quoted? from what i know the rear seat need to be moved, but that all.
Re: Question on spring install?
Originally posted by dfv3.2CL-S
Need quick answer because dealer wants to charge more than what was quoted?
Spectacular Aroma About
They initially quoted 6 hours for $465 plus 60 for alignment. Now they are saying that the technician needs to remove the rear panel deck where the speakers are located and need to add two hours. Then they come up with the BS that because my amp is installed to the metal shelf it need to be removed for him to do the spring install/work. I think they are full of crap and just want to charge another coupke hundred dollars. I express my discontent with service personnel and I will find out tomorrow the results.
Busy Living
they trying to screw you. shelf doesn't have to be removed. tell them you'll bring your socket set over there and take those two bolts out yourself in 5 mins. I think it's a 15mm socket. no way whatsoever do they need to take the shelf out. I thought the thing was welded in and not possible to remove. I could be wrong about that thouh
yes, it Gunn Acura in San Antonio, TX. After all they backed the initial quote. Car looks much better and handle ten times better than stock car. I need to get rid of the dam Michelin tires. BTW, they are not to much of mod friendly. Because I noted on the dealer paper work, it states, install customer spring followed by No warranty. Its funny, I had my sways and header install at Goodson Acura in Irving, TX and none of that BS was placed on the paper work.
6 hours and then another 2 because of the rear seat??????????????? OWOWOWOWOW .Dude it should cost you 3 hours labor plus whatever the alignment is .We charge 3 hours to lower a CL or TL .
Jens
Jens
cycdaniel
12-17-2019 10:58 AM
Skirmich
09-15-2015 06:41 PM
