Question for header owners
Old Feb 22, 2001 | 10:53 PM
GoldTypeS_RENAMED's Avatar
For those of you that have installed Comptech headers...
How would you describe the change in engine sound after the installation. Be as specific as possible if you could. I'm looking for opinions of both noise level and quality of sound at all rpms.
Thanks!!
2001 Acura 3.2CL Type S
Comptech Springs
Comptech Sway Bars
Comptech Headers
PIAA 19169
Old Feb 23, 2001 | 12:30 AM
Jens H.'s Avatar
retired
To be honest having installed several of these I would say there is little if any change in sound that I could hear.Jens
1992 mazda Miata lowered with Eibach springs KYB AGX adjustable struts Sparco racing buckets 4 point safety harnesses Momo steering wheel lo profile headlite system with PIAA superwhite bulbs Custom audio system Custom gauges Jackson racing supercharger with header and Greddy cat back exhaust and a ton of other stuff 2000 Honda Civic on APEX coilovers Full Alpine Audio system factory fogs with Piaa bulbs Catz ZETA headlamp system tinted custom taillites and on and on
Old Feb 23, 2001 | 09:59 AM
C'mon guys..... NOT ONE RESPONSE from an actual header owner!!!
Thanks, Jens for your input, though.
I realize there isn't a lot of change, but the sound IS different. I'm trying to determine if my headers have an exhaust leak. I **think** I can hear a very faint hissing sound above 5000rpm. I've got about 80 miles on my headers now and I can detect a slightly stronger pull above 5000rpm, but not much. I don't know if I was just expecting too much or if I have a problem.
Old Feb 23, 2001 | 11:02 AM
fender4's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Jens Heydel:
</font>
Jens
Does the removal of the heat shields cause any effect? Honda designed them for a purpose and I would like to know it. It might have been to keep fingers from burning but I bet in their heat transfer models something in that area gets too hot. Any thought or seen any problems??
Old Feb 23, 2001 | 12:11 PM
Brack's Avatar
I didn't notice any change in the sound. I did notice an increase in power.
Mike
Satin Silver CL Type S
Old Feb 23, 2001 | 12:13 PM
Brack's Avatar
Mike
Old Feb 23, 2001 | 01:02 PM
Jonny Blaze's Avatar
I noticed the boost in acceleration from a stop. No noticible engine noise. I had my car next to one at the meet that didnt sound different at all except for my exhaust.
CL-S BLK on BLK
Navi,mudgaurds,
spoiler,NUspeed crappy springs dropped 1 3/4 in ,35%,sitting on 19" Altstadts & Nitto 555 235/35/19s
Comptech headers and sways.
GReddy Dual MX exhaust
AEM custom CAI
Old Feb 23, 2001 | 01:07 PM
MCHM3's Avatar
magnet
no change in sound only horsepower
2001 cl type s,custom voltage blue paint job, comptech headers, 18 inch ssr agle strusse rims, greddy evo exhaust, cross drilled rotors, pioneer avx 7000 tv, playstation2, iceman cold air intake(custom)nos fuel pressure regulator, slammed on nex suspension
my old car www.hondatech.org/99acv6ic.html
my cl-s
Old Feb 23, 2001 | 02:00 PM
NOVAwhiteTypeS's Avatar
I do notice a little i mean very faint noise in increase. You can hear it when you have your music off completely. It just sounds like air moving through pipes like exhuast noise but very very faint. Won't even notice it if you have music on all the time like me. The sound is almost like a little uoooo ,uhoooo sound only when I give it gas. You probably won't be able to tell, don't worry.
CL-S
White/Ebony/Navi/Spoiler/Visor/Full Bra/Mud Guards/Cargo Net/Acura Car Cover/Tint 20%,35%,5% on Sun Roof, Rockford 250a2 Amp w/JL10w6 / K&N Drop in Filter. Comptech Springs. Polarg m-6.
Comptech Headers, Comptech Sways, Eurolite Xenon Crystal high beams.
AEM CAI once they decide to make the dame thing.
235/40/17's or 225/45/17's once I found out which one works for me.
gtech 0-60 6.03 w/ 438 pound load. preheader.
Old Feb 23, 2001 | 02:30 PM
delmonk's Avatar
I got them installed last weekend.
There may be a slight increase in noise but not large enough for me to notice. I have the music on almost all the time mostly.
01 Silver CL Type S
PIAA roadlamps, Comptech Springs, Comptech Headers, Comptech Swaybars, Zaino Shine
Xephyr Performance CAI when I get it
Old Feb 23, 2001 | 03:10 PM
FDao's Avatar
GoldTypeS,
I would seriously consider retorquing your headers, as the hissing sound that you hear may very well be leakage. I say this because when I had headers installed on my Prelude Si, I too had a hissing sound above 4000 rpm. After checking, I found that there was not a tight seal. Also, you should look into getting header gaskets which can prevent further leakage along with retorquing your headers.
Frank
01-S White/Parchment
Comptech Sways & Springs
Old Feb 23, 2001 | 06:33 PM
JZ's Avatar
JZ
I assumed that the hissing sound was the sound of the escaping gases passing through the thinner walls of the headers. I have always heard that at high rpms and I have, in fact, had my headers retorqued about two weeks after they were put on. The guy who did them was also very careful to inspect for leaks both times he tightened them. I think this is normal. Besides, if it is the same hissing that I am referring to you can only hear it if you listen carefully without the radio on and only at high RPMS. Plus, no heat shields to deflect/absorb sound may also play a slight role in this.
Black/black CLS
Comptech headers, springs, swaybars
Koni yellows
PIAA 19169 road lamps
Solaris Hi beams
Potenza RE730 225/45/17
35% tint/CAI next
Old Feb 23, 2001 | 09:15 PM
so cal type s_RENAMED's Avatar
2-2.5k is a little bit louder, IMHO.
'01 cl-s blk/blk :: comptech headers, comptech springs, comptech sway bars
vaughanml2
Nov 1, 2021 10:16 AM
IIDXholic
Oct 8, 2015 07:53 AM
V-tecAc
Sep 21, 2015 09:25 AM
datadr
Sep 12, 2015 09:12 PM
Steven Vitek
ILX
Sep 10, 2015 07:29 AM
