Problem
Old Jun 12, 2008 | 11:09 PM
ericb369's Avatar
Problem
Hey I have an 01 cl type s.. Having a problem.. I went to start the car yesterday after it sat all night... i kept cranking and would not start....i cycled the key a few times thinking the fuel pump wasnt working it eventually started. Then it worked fine the rest of the day.....then when it sat over night same problem real rough time starting..i replaced the coil packs and plugs like 6 mos ago..... what could it be?
Old Jun 12, 2008 | 11:11 PM
YeuEmMaiMai's Avatar
fuel leak down? easy way to checl is to put a fuel pressure guage on it and check it the next day.
Old Jun 12, 2008 | 11:27 PM
ericb369's Avatar
Yeah i am not really sure...someone said the fuel pump or the fuel filter...
Old Jun 13, 2008 | 08:36 AM
fuzzy02CLS's Avatar
The fuel filter is attached to the fuel pump which is in the gas tank.
You sure your battery is ok? Cables?
Old Jun 13, 2008 | 09:41 AM
ericb369's Avatar
Its funny you mention the battery... There was some corrosion around the terminals about a week ago and it cause problems during start , i cleaned it off though. And when that happen it wouldn't crank at all... it is cranking strong now and the radio/nav kicks on so there is good power... its odd i got done work at 11:30 pm last night , started right up...I had to go somewhere this morning at 8am started right up...so i am not sure what is going on or even what to do ??
Old Jun 13, 2008 | 09:54 AM
fuzzy02CLS's Avatar
Get the battery tested. Most auto stores will do it for free.
Old Jun 13, 2008 | 10:21 AM
pai_gow's Avatar
Who did this in
Agreed. I had leakage around my battery which was causing starting problems. Replaced it with a YellowTop and necer looked back.
Old Jun 13, 2008 | 10:40 AM
ericb369's Avatar
ok i will thanks...i just find it hard to believe its the battery when it seems to be cranking really strong...
SidhuSaaB
May 30, 2020 12:40 AM
Fool
Mar 10, 2016 08:42 PM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
