ported/bored throttle body
Old Jul 13, 2012 | 10:02 PM
njlakeshoreg's Avatar
who is running one??
i was thinking of getting mine done
i have a 03 cls 6mt with aem intake, p2r spacer comptech headers, axle back and custom mid pipe and aem pulleys as far as performance
will i benefit? and is there anyone that sells them or amybe i can send mine in as a core???
mike
Old Jul 15, 2012 | 04:06 PM
03CLSMT's Avatar
you can take it off and take a dremel to it. Cover the IAVC hole with something so metal shavings dont get in there. I did mine myself its easy but Id suggest going to buy a micrometer so u can get an idea of the size. Just try your best to be even...you can youtube it
Old Jul 15, 2012 | 04:37 PM
RooEng's Avatar
You just smoothed it not increased the bore? What were the gains?
Old Jul 16, 2012 | 09:42 AM
03CLSMT's Avatar
No, i did. I just didnt do a lot bc its my first time doing and not sure the exact size because i dont have a micrometer and im buying an 80mm one soon. I just did it for fun one day.
Old Jul 16, 2012 | 06:57 PM
i have a dremel and i have messed around before with it, but i dont trust myself to make it properly smoothe........
also next idea woul;d be get a universal 80mm on ebay, but not sure if there is one basically that will take a perfect fit, i have not looked into all the info
Old Jul 16, 2012 | 07:43 PM
AcuraSpook's Avatar
Weird
That aem intake isn't going to flow enough for a 80mm tb IMO.
As far as porting and polishing, a lot of people don't realize how hard it is to actually improve flow, usually its reasonable to get a port and smooth from a lace that can actually flow bench and make sure flow was improved. Not to mention maintaining a perfect mating between tb and manifold.
Old Jul 17, 2012 | 10:00 PM
i agree, that is why i am not doing it myself :0)............
if i do a larger tb i will have a 4" intake made.......
also does the aem v2 fit 6spd??
Old Jul 18, 2012 | 02:01 PM
AcuraSpook's Avatar
Weird
No. Not direct anyways. You can make it work though. I've seen it on here, can remember who though. It was designed for the j32a1 in the P
Old Jul 18, 2012 | 07:09 PM
thanks, i wonder if i would have to cut it since i dont have the vsa....i think i saw that somewhere
MrHeeltoe
20
Feb 23, 2023 01:54 PM
Jinkazetsukai
Nov 21, 2015 05:28 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
Username 0
2G TSX Performance Parts & Modifications
23
Sep 28, 2015 09:09 AM
