pinstripe
Old Mar 27, 2007 | 07:50 AM
OrngeAc3.2's Avatar
pinstripe
quick question....i have an PDG 01 cl-s....an i have that annoying black pinstripe and thinking about removing it....is this something i could do on my own or should i bring it somewhere...any suggestions appreciated, thanks
Old Mar 27, 2007 | 07:53 AM
RaviNJCLs's Avatar
Unless it's painted on, you should be able to remove it. Hopefully the paint is not a different shade under the stripe. I've seen that with some cars that have been debadged.
Old Mar 27, 2007 | 08:01 AM
OrngeAc3.2's Avatar
thanks...the only thing thats not making me too mad about it is that all of the windows on my car are blacked out (including windshield), so its not TOO hard on the eyes....
new pic in avatar? cute kid! thanks again
Old Mar 27, 2007 | 08:08 AM
RaviNJCLs's Avatar
Thanks. Little man is growing up fast.
I would try to take a small area off and see if there is a difference. I had a pin stripe on my green Maxima and took it off without a problem. Give it a shot.
Old Mar 27, 2007 | 08:10 AM
RaviNJCLs's Avatar
By the way, this thread was listed below. Smitty had some good advice. I'm not sure about using a razor blade.
http://www.acura-cl.com/forums/showthread.php?t=137829
Old Mar 27, 2007 | 10:36 AM
SFAJeff's Avatar
You can get it off even if it is painted on, I just had to do this on my 01 SMR. It had horrible gold and black pinstripes when I bought it and I used Easy Off oven cleaner to remove the pinstripes.
Old Mar 27, 2007 | 10:51 AM
Sun Diego CL-S's Avatar
says "hello to my TLX".
aren't many pinstriping jobs done in a paintshop? they usually do the pinstriping on the paint before they apply the clearcoats. if this is your case, you'll just have to learn to live with it.
<-- doesn't care much for pinstriping.
Old Mar 27, 2007 | 10:54 AM
RaviNJCLs's Avatar
Depends on the person that put it on. Sometimes it's painted. Both cars that I have had that had/has pin-striping, it's not painted on.
Old Mar 27, 2007 | 11:23 AM
NSXNEXT's Avatar
There was no "factory" striping. It was a dealer option.
Old Mar 27, 2007 | 11:33 AM
nbennettksu's Avatar
i heart latin chicks
I just removed my pinstripe. Get a hair dryer, plastic razor (don't worry, it WILL NOT scratch the paint), and an extinsion cord. Heat up about 1ft, use the plastic razor to lift the corner, and start pulling.
**hint, pull lightly, keep removed stripe at a 90º angle and you can get in a rhythm.
There will be a gummy substance where the stripe was removed, but you can to go Target/Walmart/PepBoys and get a goo remover.
Take that pinstripe off!!!!
Old Mar 27, 2007 | 12:15 PM
OrngeAc3.2's Avatar
just went out and looked, def. looks like it's painted on...
Old Mar 27, 2007 | 12:53 PM
RaviNJCLs's Avatar
Enjoy having that pin stripe there. Get used to it.
Old Mar 27, 2007 | 01:05 PM
OrngeAc3.2's Avatar
haha, that's what i was just sayin to myself...thanks for the input guys--get out there and enjoy that weather!
Old Mar 27, 2007 | 01:30 PM
SFAJeff's Avatar
You can still get it off, here is the link to the instructions I followed when removing my pinstripes.
http://cleangsx2004.tripod.com/pinstripe.htm
Old Mar 27, 2007 | 01:39 PM
OrngeAc3.2's Avatar
no signs of f'in up the clearcoat after you tried?
Old Mar 27, 2007 | 03:20 PM
SFAJeff's Avatar
Nope, worked well. Just take your time and test on a small area first and you should be fine.
Old Mar 27, 2007 | 03:27 PM
SFAJeff's Avatar
Oh yeah, the other thing I forgot to mention was that it speeds up the process if you heat up the area you are about to remove the pinstripe from before applying the Easy Off.
yea you can still do it, its just a great deal more tedious. And they're right, it won't F up your clearcoat. If you've kept good wax on her, there won't even be any discolorage!
Old Mar 27, 2007 | 10:14 PM
RYANGP's Avatar
Not a doctor
ah dude this is awesome!
i can finally remove that damn sword and shield on my trunk haha
thanks man
Old Mar 28, 2007 | 01:04 AM
Jrezo's Avatar
CLS-6
Now that you mention it I dont think that I have ever even seen it on our cars. I do remember the accord the the H embelem on the back 1/4 panel if I remember right.
OrangeAC3.2 Any pics of the ride, do before and afters???
uzzmaan
Aug 4, 2025 08:29 AM
bklynpanman
3G TL Photograph Gallery
52
Mar 28, 2005 09:56 PM
destin
Sep 9, 2004 10:21 AM
ITL
Aug 29, 2004 09:57 AM
