PIAA Road Lamps - Need help again
Okay, some of you may remember that I had a horrible time getting these stupid road lamps out so that I could install the PIAAs. Well, finally, after I got the right size screw driver, I have been able to get the housing out.
My question now is.....I have the PIAA 19224s (I think thats the number) but they are the 18w bulbs. AFter I "plugged" them into the "socket" and then tried to re install them into the housing.....it barely fit, I almost had to jam it in there. Is that normal??
Also, I turned the lights on for about 20 secs just to see how it looks and the from plastic part on the front of the house heated up immediately!!! Is that normal??
Thanks for the help again guys!!!
Mugen Racing Team
Yes its normal, you have to twist and turn slighty to fit the 19224 in, and yes its heats up quickly since its 18w whereas the original ones are 5w. Its all normal just try not to use the xenon as often so the housing will last longer. Use the headlights only when u really need to use it.
Mugen Racing Team
I was using Polarg 5W pink before i got booked by cops, then i changed to 19224. Started using them in Dec and so far so good and no sign of melting yet. The 19169 is the same colour as 19224 but a 5W version therefore not as bright. If you afraid of melting use the 5W bulbs and you'll have a great selection of colours to choose from whereas the 18W are brighter but only the Xtreme white.
I think I'm going to use the 18ws for now and order the 5 watts to be on the safe side
Well, just a quick prop out to eveyone on this board. I finally have my road lamps installed and all because of the help from everyone here. And they look great too!! I really appreciate some of you who have taken time to answer my "newbie" questions at times.
Thanks again
Thanks again
Originally posted by NoleCLS
"booked by the cops"??? is it illegal to change out the road lamps??
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
Eggs999bacon
09-24-2015 10:08 AM
