Outta gas?
Outta gas?
Has anybody ever run out of gas in their 01-03 CLS? I'm just curious seeing as I read back a while ago that the car has some type of filter that recirculates unused gas fumes back into the engine. I've gone past the empty needle as far as my heart could take it and never run out of gas and I know I've burned at least 3 or 4 gallons past empty.
there is exactly 3 gallons left after the gas light goes on. i've never ran out before but i've gone pretty far past E. i just try to find a gas station before the needle hits the peg on the cluster.
Uses turn signals in my
When my gas light has come on and I fill it up shortly after, there is usually 4.1x gallons left out of the entire 17.2
Don't Mess With Texas
i was driving home the other night when it was really late and no gas stations i passed were open. i had to fill up in the morning and the car took 17.1xx gallons O_O
Originally Posted by fuzzy02CLS
I have never run out of gas in anything. I just don't see how people do?
How hard is it to buy gas when your gauge is at a 1/4 tank?
I agree with fuzzy....on very rare occasion's does my CL ever get below 1/4 of a tank of gas, dont like to suck up all the debris sitting in the bottom of the fuel tank!
Back in a TL again.
:slap:
where do you think your fuel pump sucks gas from the top of the tank it sucks the fuel from the lowest point in the gas tank so what debris are you talking about?
I ran out of gas twice in my old 2.2CL. The first time I was parked on a hill with the front end facing down. The second time the car was sitting passenger side downhill. Gravity had more to do with actually running completely out of gas on those occasions. The point I was trying to make in asking the question of anyone running out of gas is if the filter system somehow increased the actual mileage due to fumes being reintroduced to the engine from the filter. Don't make me go back and research about the filter in my manual again because I left it at my other house. Otherwise, no I've never run out of gas in my CLS.
I'll also add that the fuel filter is attached directly yo the fuel pump in the tank. So this minimizes the chances of anything plugging up the fuel system.
And I'll also say that I'm not sure what these "bottom of the tank debris" are. I had the gas tank out of my 94 explorer with 100K miles on it & the inside while discolored didn't have anything in it.
I think crud in the tank was a bigger problem in the past. Probably in no small part due the rate at which we, the public, use gas, it doesn't spend nearly as long hanging out in the underground storage tanks at the station. Also, most gas tanks are plastic these days so they aren't going to rust or flake off the anti-corrosion coating.
CL-Pride
For those who had run out of gas. How many time did your CL stall before it is completely empty. I ran out of gas on my grandpa's sienna once, and usually it takes 3 to 4 stalls to go completely out.
i heart latin chicks
Originally Posted by vetalik
:slap:
Back in a TL again.
i ran out of gas on my tl, it sputtered/ stalled 3 times on the fourth times i was already rolling into the gas station had to push it couple feet.
Ive never ran out of gas in the CL yet due to the fact that gas is so expensive right now, and every time i get to about half a tank i fill up!! I was told that if you fill up before you go empty you save $!!
CL-Pride
I heard something else, you save more $$ when running with less gas and better for your car.
1. Less gas in tank = less weight
2. Using most of the gas in your tank helps burn off all the stuff sitting in the bottom of the tank.
Man I save money, think what u want!!!
i think your are actually just spending less money every time you go to the pump(which is more often than if you actually ran your car to E)
wouldn't you save more by only filling the tank halfway and running it to empty. you would have half a tank less the weight. the benefit in mpg would be less than 1 more than likely. not even worth my time of filling up twice as often.
VIP-
i am lost on the physics of how your method improves mileage. any further explanation?
VIP-
Originally Posted by cltypeSLOW
lol are you sure?
