Outta gas?
Old Jan 8, 2008 | 04:39 PM
Sideswipe's Avatar
Outta gas?
Has anybody ever run out of gas in their 01-03 CLS? I'm just curious seeing as I read back a while ago that the car has some type of filter that recirculates unused gas fumes back into the engine. I've gone past the empty needle as far as my heart could take it and never run out of gas and I know I've burned at least 3 or 4 gallons past empty.
Old Jan 8, 2008 | 05:40 PM
sinfulj32's Avatar
there is exactly 3 gallons left after the gas light goes on. i've never ran out before but i've gone pretty far past E. i just try to find a gas station before the needle hits the peg on the cluster.
Old Jan 8, 2008 | 07:27 PM
underst8's Avatar
140,000 miles young
yeah. i think i've done 50 miles after the light went on cause there were no gas stations along the highway, which sorta had me worried
Old Jan 8, 2008 | 07:55 PM
o1s's Avatar
o1s
my gas light comes on when i have a bout 4 gallons left. it only take 13.5 to fill it up as soon as the light comes on.
Old Jan 8, 2008 | 08:02 PM
TCM 01 CL-S's Avatar
Uses turn signals in my
That last sentence reminds me of a Seinfeld episode involving a Sabb...
When my gas light has come on and I fill it up shortly after, there is usually 4.1x gallons left out of the entire 17.2
Old Jan 9, 2008 | 08:17 AM
fuzzy02CLS's Avatar
I have never run out of gas in anything. I just don't see how people do?
How hard is it to buy gas when your gauge is at a 1/4 tank?
Old Jan 9, 2008 | 08:36 AM
cltypeSLOW's Avatar
Don't Mess With Texas
i was driving home the other night when it was really late and no gas stations i passed were open. i had to fill up in the morning and the car took 17.1xx gallons O_O
Old Jan 9, 2008 | 11:39 AM
TOPHER33884's Avatar
I agree with fuzzy....on very rare occasion's does my CL ever get below 1/4 of a tank of gas, dont like to suck up all the debris sitting in the bottom of the fuel tank!
Old Jan 9, 2008 | 03:52 PM
o1s's Avatar
o1s
that's what a fuel filter is for.
Old Jan 9, 2008 | 04:28 PM
BENDER08's Avatar
Back in a TL again.
:slap:
where do you think your fuel pump sucks gas from the top of the tank it sucks the fuel from the lowest point in the gas tank so what debris are you talking about?
Old Jan 9, 2008 | 06:41 PM
Sideswipe's Avatar
I ran out of gas twice in my old 2.2CL. The first time I was parked on a hill with the front end facing down. The second time the car was sitting passenger side downhill. Gravity had more to do with actually running completely out of gas on those occasions. The point I was trying to make in asking the question of anyone running out of gas is if the filter system somehow increased the actual mileage due to fumes being reintroduced to the engine from the filter. Don't make me go back and research about the filter in my manual again because I left it at my other house. Otherwise, no I've never run out of gas in my CLS.
Old Jan 9, 2008 | 08:10 PM
fuzzy02CLS's Avatar
Now I've been in a few cars driven by other that ran out of gas. Maybe that's why I don't run empty.
Pushing a 15 passenger Ford van is not fun!
Old Jan 10, 2008 | 07:51 AM
LukeaTron's Avatar
The charcoal canister you're talking about is used to purge the fuel line of gas vapor when it's initially pressurized. There's a hose that draws the vapor out via the intake manifold once the engine is running. It's mostly an emissions thing and will do nothing to help you if you run out of gas. Every car has had these for at least 10 years now, maybe even 20.
Old Jan 10, 2008 | 09:00 AM
GreenMonster's Avatar
I've only run out of gas with a car that didn't have a working gas guage... needless to say it's been about 20 something years ago...
Old Jan 10, 2008 | 10:10 AM
OrngeAc3.2's Avatar
dont think my gas light has ever come on....it's like not feeding your children!! i dont let mine go below 1/4
Old Jan 10, 2008 | 11:40 AM
Cocoa's Avatar
2600lb CL
Just keep in mind that your fuel pump needs to be submerged in fuel in order for it to cool down.
Old Jan 10, 2008 | 12:21 PM
fuzzy02CLS's Avatar
I'll also add that the fuel filter is attached directly yo the fuel pump in the tank. So this minimizes the chances of anything plugging up the fuel system.
And I'll also say that I'm not sure what these "bottom of the tank debris" are. I had the gas tank out of my 94 explorer with 100K miles on it & the inside while discolored didn't have anything in it.
Old Jan 10, 2008 | 12:28 PM
LukeaTron's Avatar
I think crud in the tank was a bigger problem in the past. Probably in no small part due the rate at which we, the public, use gas, it doesn't spend nearly as long hanging out in the underground storage tanks at the station. Also, most gas tanks are plastic these days so they aren't going to rust or flake off the anti-corrosion coating.
Old Jan 10, 2008 | 01:17 PM
ironsurfer129's Avatar
CL-Pride
For those who had run out of gas. How many time did your CL stall before it is completely empty. I ran out of gas on my grandpa's sienna once, and usually it takes 3 to 4 stalls to go completely out.
Old Jan 10, 2008 | 01:45 PM
nbennettksu's Avatar
i heart latin chicks
by
Originally Posted by vetalik
:slap:
Old Jan 10, 2008 | 01:50 PM
BENDER08's Avatar
Back in a TL again.
i ran out of gas on my tl, it sputtered/ stalled 3 times on the fourth times i was already rolling into the gas station had to push it couple feet.
Old Jan 10, 2008 | 10:24 PM
VIPCLS's Avatar
P.
Ive never ran out of gas in the CL yet due to the fact that gas is so expensive right now, and every time i get to about half a tank i fill up!! I was told that if you fill up before you go empty you save $!!
Old Jan 11, 2008 | 08:43 AM
cltypeSLOW's Avatar
that is the dumbest thing i have ever heard.
Old Jan 11, 2008 | 11:11 AM
CL-Pride
I heard something else, you save more $$ when running with less gas and better for your car.
1. Less gas in tank = less weight
2. Using most of the gas in your tank helps burn off all the stuff sitting in the bottom of the tank.
Old Jan 11, 2008 | 12:04 PM
BENDER08's Avatar
Back in a TL again.
Old Jan 11, 2008 | 12:06 PM
uhh yeah, x2
Old Jan 11, 2008 | 01:15 PM
VIPCLS's Avatar
P.
Man I save money, think what u want!!!
Old Jan 11, 2008 | 02:15 PM
cltypeSLOW's Avatar
lol are you sure?
i think your are actually just spending less money every time you go to the pump(which is more often than if you actually ran your car to E)
Old Jan 11, 2008 | 02:56 PM
distortedolskool's Avatar
wouldn't you save more by only filling the tank halfway and running it to empty. you would have half a tank less the weight. the benefit in mpg would be less than 1 more than likely. not even worth my time of filling up twice as often.
VIP-
i am lost on the physics of how your method improves mileage. any further explanation?
Old Jan 11, 2008 | 03:28 PM
BENDER08's Avatar
Back in a TL again.
i get better aerodynamics due to all the stickers on my car so that gives me hp+ and +mpg
Old Jan 12, 2008 | 12:55 AM
VIPCLS's Avatar
P.
lol are you sure?
Man I know what your sayin and I agree. What im goin on is the salesman that sold me the vehicle said, if you fill up at half a tank you actually save money. It might not be true, it might be just a myth, and not a fact? Also the way gas prices are always fluctuating. Sometimes to me it seems like a smarter way to buy gas before the prices goes up any more, before it gets to E. But I dont always use this same method when filling up, I often run a whole tank to E, but usually fill up before I get to E, thats all im sayin.
xsilverhawkx
Oct 5, 2015 11:00 AM
MilanoRedDashR
Oct 2, 2015 10:49 AM
Skirmich
Oct 1, 2015 12:59 PM
San Yasin
Sep 29, 2015 10:52 AM
