option racing pulley install
For those who have installed the option racing crank pulley, what is the Crankshaft Pulley Bolt Torque Specification becos I was at the shop today and the tech was asking me for the recommended torque .
He said since the racing pulley is lighter that the torque specs should be diffrent frm OEM crank otherwise it could crack if too tight or come off if NOT tight enuff
Pls someone who has installed this racing crank pulley , tell me what the recommended specs is ??
CL-S 6Speed is rarely in
Not trying to hijack your thread, but I too am installing this same pulley over the weekend and also need the torque specs. Did you get a new crank bolt? I replaced the hamonic balancer and crank pulley on a Supercharger XR7 I owned (replacement factory) and didn't replace the crank bolt. Two weeks later the crank bolt snapped and I damaged the new pulley and balancer. The forum I belonged to (SCCOA.COM) had this happen to others that didn't replace to bolt. Needless to say I replaced to bolt the second time. Is this nessacary for the CL?
Joe
Joe
Originally Posted by poisx7
so i am confused, are u saying 181ft-lbs is recommended but u used 150.
pls SB clarify.
pls SB clarify.
Originally Posted by CH46ESeaKnight
That is the TQ spec. But I used about 150 on the new aluminium pulley.
S0 go with 150 vs 180 .
I wonder if one could really crack the pulley if it is torqued to close to 180lb.
Alternator & A/C Belt: Accord, CL & TL: Use Gates K060441 (44 5/8” or 1135MM)
Power Steering Belt: Use Gates K040425 (43 1/8” or 1095MM)
Originally Posted by p.diddy
i have to change both belts even though im only changing the crank pulley?
The power steering belt is powered by the crank pulley. So yes you need both belts.
Thanks Man for the help, I will try that.
I know a few ppl have installed this Option racing pulley or unorthodox pulley but NOT many are commenting on the torque specs they used when they installed it .
Pls shhhhhhhhhhhhhaaaaaaaaaaaaaaaarrrrrrrrrrrreeeeeeee eeeeeee
do u really think the new pulley will crack if i went as high as 180lb.
well...... i give up.
hehehhe
i will just use what ever insructions that was posted on unorthodox website. plus the advise CH46ESeaKnight gave. thankz Again CH46.....
Originally Posted by fuzzy02CLS
Once it's tight it's tight. I didn't install it so I have no idea what was used. 180 will be fine. Your not going to break anything.
Just do it & stop stressing about it.
Agreed, just make it tight. 120 Ft lbs to 180 Ft Lbs is fine. You might be able to do it just fine around a hundred. It's not going to come off at thoes specs.
I would'nt worry about it too much.
I only said 150 cause I used an impact. Once it was tight I just hit it a bit more. Good enough!
If your not used to using a impact gun, I'd be carefull as to not over TQ it. It can be easy to do with a good Impact Gun.
Uses turn signals in my
who sells the gates belts? autozone, napa?
http://www.gates.com/buy.?location_id=3362 Nearest store that sells gates' parts locater.
is there anything wrong with buying the belts from autozone or napa for example. are those belts not good.
I went to Checkers and got the Goodyear Gatorback belts. Seem to be just fine! I'd go pull the numbers for ya, but my CL is getting a new tranny. Won't have it back for another week or so!
Any of them can translate the belt numbers for you. ( well they should, but you might get someone whos knows nothing about belt numbers).
Originally Posted by 02CL-TypeS
are you going to install it yourself? I don't ahve any mods to my car and don't plan on getting a CAI cause I have 02 fog lights so this looks like a good first mod.
I could only find the gates belts online. No retail store had them.
MP90 uninstalled
Originally Posted by 03_Type_S
Is that so it doesn't squeel? like some have stated
Anyone know about this issue? I probably have the crank bolt at 120ftlb. I have had squeel at idle on both my OE size UR crank pulley and my smaller UR pulley. It is so annoying. It started on both pulleys after about 1000 miles. Tension on PS belt is good and new tensioner on accessory belts at this time and still I have a squeel at idle that gets worse with the ac on. I tried belt dressing on the old small UR pulley and that would make it stop for a few days. Jim
If all eles fails try the Goodyear Gator back belts. They have a soft compound, and slits in the ribs for flexing.
Mine has never made any noise. Of course I only have about 500 miles on it. I wonder if that Supercharger might have something to do with the belts sqeeling. Maybe more drag on teh system. I'm sure you've tried but maybe try tightning them up a bit? Or maybe they are to tight?
i just did mine at 165 lb, so I dont think so.
I will wait for a while though. I got maybe 5 miles on them but we will see.
yet to notice the HP jump frm the crank pulley though unlike the cai or seafoam or the headers or enlarged Tb those were all noticable almost instantly.
time will tell.
i got my pulley installed today i can really feel the difference. the rpm's jump alot faster. i love the acceleration my car has now.
MP90 uninstalled
I think it may be my tensioner. I just replaced it 30000 ago. what the hell?
cycdaniel
12-17-2019 10:58 AM
09-15-2015 06:44 PM
Mugen TSX
Eastern Canada
09-01-2015 11:11 PM
