optima yellow top?
Old Feb 25, 2006 | 05:15 PM
Frink's Avatar
optima yellow top?
According to Optima, they don't make a yellow top for the '03 CL-S. I've seen pics of them in the CL though. Does anyone know which one I should get? I've looked everywhere for a definite answer w/ no luck. Any help would be much appreciated.
Old Feb 26, 2006 | 09:25 AM
dj5's Avatar
dj5
I have an Optima red top 34/78. The 34/78 yellow top will also fit.
I got the red top because I don't have an aftermarket stereo system, and the red top actually has more cold cranking amps than the yellow top. The yellow top will take more full drains than other batteries before it is damaged.
So unless you have an aftermarket system, I would recommend the red top over the yellow top.
Old Feb 26, 2006 | 12:21 PM
Titand19's Avatar
East Coast Boost.!
it's a battery. meaure the stock battery and then see which YT model best fits.
Old Feb 26, 2006 | 06:23 PM
Standout's Avatar
National Champs GO GATORS
you have to modify the tie down to have fit.... i have it my car, i just had my shop do it for me for free.... i love the yellow top!!
Old Feb 27, 2006 | 04:13 AM
Hobo's Avatar
Flap.
if you are a cheapass like me you can just put a block of wood under the battery so the tie down works
Old Feb 27, 2006 | 04:38 AM
NiteQwill's Avatar
Adventurist.
The Optimas come with spacer/adapter plates. It should be snapped into the bottom of the battery. At least my Optima red top did.
Old Feb 27, 2006 | 04:46 AM
Osamu's Avatar
i believe these are the ones to get....
i think you could use a bluetop model D34M? as well....
i bought a blue top for my legend, because it was the cheapest (at least where i got it) and had more ccas then the yellow, but was still a true deep cycle battery. i believe the blue are the only one's available dual purpose starting/deepcycle, even though they are meant for marine use. i've had mine for a year or two without a single problem yet
Old Feb 27, 2006 | 08:18 AM
dj5's Avatar
dj5
My Red Top 34/78 came with the bottom spacer that snapped onto the bottom.
No adjustments to the tie downs were needed when using the spacer provided.
Old Feb 27, 2006 | 11:24 AM
phipark's Avatar
Not Asian
that's exactly what I did.
I have the 34/78
Old Feb 27, 2006 | 12:18 PM
pai_gow's Avatar
Who did this in
I've got a yellow top and grabbed a red top spacer. Fits perfectly and no issues with the tie downs.
Old Feb 28, 2006 | 06:54 PM
Frink's Avatar
Thanks for all the info, I got a yellow top 34/78 over the weekend and the guys at pep boys gave me a space and it fits fine. I got the yellow b/c I'm in the process of upgrading my system...next step is Stinger alternator...thanks again
hashbrown
Feb 18, 2022 11:20 AM
Acura604
20
Aug 5, 2017 12:55 AM
CL-S progression 01
Jan 26, 2016 04:15 PM
LogicWavelength
3G TL Photograph Gallery
33
Nov 1, 2015 09:38 AM
jmaxima03
Sep 27, 2015 10:22 AM
