optima yellow top?
optima yellow top?
According to Optima, they don't make a yellow top for the '03 CL-S. I've seen pics of them in the CL though. Does anyone know which one I should get? I've looked everywhere for a definite answer w/ no luck. Any help would be much appreciated.
I have an Optima red top 34/78. The 34/78 yellow top will also fit.
I got the red top because I don't have an aftermarket stereo system, and the red top actually has more cold cranking amps than the yellow top. The yellow top will take more full drains than other batteries before it is damaged.
So unless you have an aftermarket system, I would recommend the red top over the yellow top.
i think you could use a bluetop model D34M? as well....
i bought a blue top for my legend, because it was the cheapest (at least where i got it) and had more ccas then the yellow, but was still a true deep cycle battery. i believe the blue are the only one's available dual purpose starting/deepcycle, even though they are meant for marine use. i've had mine for a year or two without a single problem yet
Originally Posted by NiteQwill
The Optimas come with spacer/adapter plates. It should be snapped into the bottom of the battery. At least my Optima red top did.
My Red Top 34/78 came with the bottom spacer that snapped onto the bottom.
No adjustments to the tie downs were needed when using the spacer provided.
Not Asian
Originally Posted by Hobo
if you are a cheapass like me you can just put a block of wood under the battery so the tie down works
I have the 34/78
Thanks for all the info, I got a yellow top 34/78 over the weekend and the guys at pep boys gave me a space and it fits fine. I got the yellow b/c I'm in the process of upgrading my system...next step is Stinger alternator...thanks again
Acura604
20
08-05-2017 12:55 AM
LogicWavelength
3G TL Photograph Gallery
33
11-01-2015 09:38 AM
