Optima Battery
Old Aug 1, 2005 | 07:08 PM
kHmER Co's Avatar
mister D
Optima Battery
I'm looking to move my battery to the trunk and replace it with a Optima Yellow top, what model do I need? I'm also doing a system in the near future, should I get two batteries?.. any help is appreciated.
Old Aug 1, 2005 | 07:09 PM
kHmER Co's Avatar
mister D
also, are there any instructions on moving the battery to the trunk? what do I need to buy to do it.
Old Aug 2, 2005 | 12:19 PM
MtBikR's Avatar
Since you're doing the work now, I'd get two and run them in parallel. That should satisfy of all you future power needs. The only limitation would then fall on the alternator. I am not sure of the specific model# you need.
Old Aug 2, 2005 | 01:20 PM
phipark's Avatar
Not Asian
You don't really need a size since you are moving them to the trunk. I beliebe all yellows are the same, just different sizes.
Old Aug 2, 2005 | 02:05 PM
quicksilver10101's Avatar
750cca
Old Aug 2, 2005 | 03:26 PM
ThinJim's Avatar
I use the Optima Blue Top, Part # 34m-1050, you can get them here... http://www.remybattery.com/350/shope...cat=169&L2=&L3=
Here's a pic of my relocation to the trunk, I use a battery holder from eddiemarine, http://www.eddiemarine.com/cart/cata...oxes%2FCharger and had it smoke nickle plated. This battery holder is made for this batteries diminsions. Pictures don't do it justice. I overkilled the grounding in the trunk area as well as overkilled the ground in the engine compartment. Can't have too many groundsss........ I use 1/0 gauge on both the pos and neg wire, and the ground wire also runs to the front of the car to many grounding points.
Old Aug 2, 2005 | 03:42 PM
kHmER Co's Avatar
mister D
I like the look of the battery holder you have, do you know what size I would need to fit, and do you use the blue top by itself, or do you have another battery also, thanks!
Old Aug 2, 2005 | 03:47 PM
kHmER Co's Avatar
mister D
nevermind, I found it, but do you really need to optima battery box also? doesnt look like you're using one.
Old Aug 2, 2005 | 04:03 PM
ThinJim's Avatar
That battery holder is made for the optima you see pictured. The base of the battery holder is machined to match the bottom of the optima blue top battery. Go to the web page provided and read.
Old Aug 2, 2005 | 04:13 PM
kHmER Co's Avatar
mister D
Yeah, I clicked the wrong holder at first, but I ordered the correct one, as for the battery I'm just gonna look around locally since shipping is going to cost a lot.
Old Aug 2, 2005 | 10:42 PM
MtBikR's Avatar
That looks like a sturdy holder. I like it.
Old Aug 3, 2005 | 03:07 PM
ThinJim's Avatar
It's very sturdy. When you try to wiggle it, it moves the whole car...no movement what so ever. I'm still working on the finishing touches to cover the back with the old plastic piece that i'm cutting to fit. The holder is a very nice piece of hardware that is flawless from the manufacturer. I had this piece smoked chromed nickle, it came as polished aluminum.
Old Aug 9, 2005 | 06:36 PM
kHmER Co's Avatar
mister D
no wonder yours didnt have engraving on it, i ordered another color, polished box, black cover.. hopefully it goes with my car.. btw, i spoke to them on the phone and they will also ship them out w/o the logos.
MetalGearTypeS
Aug 29, 2016 08:28 PM
CL-S progression 01
Jan 26, 2016 04:15 PM
SilverJ
4G TL Problems & Fixes
15
Oct 13, 2015 05:14 PM
mars
Sep 28, 2015 11:03 AM
jmaxima03
Sep 27, 2015 10:22 AM
