OK i got my sways in BUT....
Old Aug 18, 2001 | 04:14 AM
Crazy Bimmer's Avatar
I have a minor clunking noise while make sharp turns... I think i read somewhere that means i need to gease it more?
Also all i installed was the rear sways, is there a big diffence if i change the stock front? I heard the comptech front sways are the same as the stock front sways... So whty change it?
Old Aug 18, 2001 | 08:10 AM
Rescuer's Avatar
Evil Bob Knieval
the clunking is from the bolts not being torqued to the correct specs. i installed mine the other day and had the same problem. torque them down more and problem solved
Old Aug 18, 2001 | 11:12 AM
Originally posted by TypeSDragoon:
<STRONG>the clunking is from the bolts not being torqued to the correct specs. i installed mine the other day and had the same problem. torque them down more and problem solved </STRONG>
thanks man, i knew it wasnt a big issue... so i wasnt really worried. I think ill do the fronts today also. If im not lazy.
Old Aug 18, 2001 | 11:28 AM
spiroh's Avatar
How is the handling? Did it take you long to install?
Spiro
Old Aug 18, 2001 | 11:36 AM
technoid's Avatar
You most definitely need to install the Comptech front sways -- they are NOT the same as the OEM sways form Acura. The front sways on our cars are hollow -- the rears are solid. That's why the rear bar is 22mm vs 19mm for stock. Even though the Comptech front sways have the same outside diameter as stock sways, they have a smaller inside diameter (i.e. their wall thickness is greater than OEM). This results in a stiffer sway than the stock sway, and a balanced suspension when used with the Comptech rear. That's the theory, anyways.
Try it, you'll like it.
[ 08-18-2001: Message edited by: technoid ]
Old Aug 18, 2001 | 03:13 PM
Originally posted by spiroh:
<STRONG>How is the handling? Did it take you long to install?
Spiro</STRONG>
HANDLES GREAT! Remeber that road that you gunned it on.. well one of the roads you gunned it.. well there was a curve on it so me and my buddy took the curve going 80!!!! Its felt soo soild!!!
BUT on the downside... the ride is harsher than before.. but ill get over that! only thing now is getting new shocks when the stock ones goes.. but i dont want any more of a stiffer ride... so DAMN! What a brotha gonna do?
Old Aug 18, 2001 | 03:15 PM
Spiro</STRONG>
it took be only an hour to do the rear...Spiro... Alot of WD-40 does help!!!! plus i even stopped to put a band-aid on cuz i cut myself.
Old Aug 18, 2001 | 04:03 PM
technoid's Avatar
You got it right, bro, when you said, "get new shocks." If you put in adjustables (like the Koni yellow's), you'll be surprised how well you can tune your ride so that the springs and shocks work together, and you'll have a ride just slightly "firmer" than stock but still have a ball in the "twisties."
Old Aug 18, 2001 | 05:28 PM
NeedForSpeed's Avatar
Need For Speed
Originally posted by technoid:
<STRONG>
You got it right, bro, when you said, "get new shocks." If you put in adjustables (like the Koni yellow's), you'll be surprised how well you can tune your ride so that the springs and shocks work together, and you'll have a ride just slightly "firmer" than stock but still have a ball in the "twisties." </STRONG>
Are they adjustabl without taking them off?
Old Aug 18, 2001 | 06:47 PM
technoid's Avatar
originally asked by NeedForHandling:
Are they adjustabl (Koni's) without taking them off?
Yes indeedy, they are infinitely adjustable after they have been installed on your car. Koni provides you with a small plastic wheel that you place on top of the shock fitting and you simply "dial" the stiffness of the ride you desire. Adjusting the fronts is trivial as they are always in easy reach.
The only tough part is adjusting the back shocks. For that, you have to remove the back seat, which takes about 10-15 minutes (once you know how to do it--gotta love that "Helms Shop Manual"). That's why I recommend that serious tuners ride around for a week or so with their back seat removed (since you gotta do that anyways when you replace the rear shocks), so that they can reach the rears to adjust their firmness to optimum settings. ]
CL-S progression 01
Jan 26, 2016 04:15 PM
Jinkazetsukai
Nov 21, 2015 05:28 PM
steve
Sep 30, 2015 09:23 PM
ExcelerateRep
Sponsored Sales & Group Buys
Sep 22, 2015 10:39 AM
