Oil
'01 CL-S Auto
Oil
Which brand of oil does everywhere prefer? I heard to stay away from Pennzoil and Quaker State because they cause sludge. I am using Castrol GTX.
My CLS has 103K and I am wondering if I should/could switch to a full synthetic like Mobil 1 or Castrol Synthetic. Maybe I should use a high mileage oil?
Thanks in advance.
Thanks in advance.
'01 CL-S Auto
sorry pimp. I tried searching for "oil" "oil preference" "recommended oil" and others and I had a hard time finding anything through the results. You have a thread off-hand?
whaever the local honda dealer puts in works just fine for me
here you go
http://www.amsoil.com/products/atm_t...dex_flash.aspx
debate on the best syn has been beaten to death,, if your still using Petro oil,, never mind,,
In the Mid-South meow
Originally Posted by htown
Mobil 1 Fully Synthetic
Switching to full synthetic at 100,000 plus can cause problems with seals and gaskets leaking....if going to syn on high miles, they say to go the blend-syn oil route first and if no problem go to full syn....
I use M1 in the acura...my 1990 gmc sub...is at 330k miles on regular quaker state every 3000 miles..??? Main thing appears to be to change oil on a regular bases....
Senior Airman
[QUOTE=Texas]Switching to full synthetic at 100,000 plus can cause problems with seals and gaskets leaking....if going to syn on high miles, they say to go the blend-syn oil route first and if no problem go to full syn....QUOTE]
It def. can cause problems.... But I started using full synthetic in my integra with 104k and it worked perfect, you just have to check on it regularly to make sure your not losing oil.
I use Lucas 5w-20 full synthetic and it runs like a Dream!
I would go for it man, worst thing that could happen is you have to another oil change if the synthetic is leaking. Just make sure you watch it otherwise you'll be sorry!
IBankMouse
06-13-2020 12:53 PM
