O2 sensor
Old May 9, 2004 | 05:14 PM
bigjohnson's Avatar
O2 sensor
Has anyone had any experiences with removing the cat converter and looping the O2 sensors on the CLS? Are there any companies that offer a module to fool the ECU?
Old May 9, 2004 | 06:35 PM
allmotor_2000's Avatar
I've run without the catalytic at the track; check-engine light does come on after a while even if the 2nd O2 is plugged in. I wouldn't recommend this for day-to-day driving. Plus in CA they have remote laser-type smog units all over the place!
Old May 9, 2004 | 07:04 PM
Sly Raskal's Avatar
I don't know what this means? enlighten me.
Old May 10, 2004 | 02:04 PM
bigjohnson's Avatar
Laser this! Out of all seriousness, there must be someone with info on the modification of the O2 sensor. Don't lecture me on "I wouldn't do it because" crap. thanks in advance.
Old May 10, 2004 | 03:44 PM
Silverbulit40's Avatar
Enjoy the Ride
if your just trying to get rid of the restriction from the cat then just get a universal hi flow cat and get a o2 bung customized onto the hiflow cat and that should solve your problem because the o2 can plug into the hiflow cat.
Old May 10, 2004 | 06:00 PM
1killercls's Avatar
GEEZER
:noob:
Old May 10, 2004 | 07:59 PM
scalbert's Avatar
What exactly do you expext to gain from this?? Little to no power increase and increased emissions?? What else is done to your car to warrant this and it had better not be an intake only??
Also, you are asking questions on an open forum; do not expect filtered responses.
Old May 10, 2004 | 08:01 PM
mattg's Avatar
you should pipe down and listen to the man. unless you are running, FI messing w/ your cat will gain you nothing.
Old May 10, 2004 | 08:15 PM
bigjohnson's Avatar
Thanks for your input, I guess there is no such solution to the O2 sensors. Good luck to you all.
TR
Old May 10, 2004 | 08:19 PM
scalbert's Avatar
There are solutions to removing the HO2S2 and fooling the ECU into thinking it is working. However, there is no real reason to do this if power is desired through removing the catalytic converter and you are not running forced induction.
Old May 10, 2004 | 08:32 PM
bigjohnson's Avatar
I am running forced induction and want to reduce the restrictions imposed by the cat. What are some of the solutions you are speaking of?
Old May 10, 2004 | 08:38 PM
scalbert's Avatar
O2 simulators are nothing new. You could easily have a pipe welded in and install a simulator.
So, you have the Comptech SC??
Old May 10, 2004 | 08:46 PM
bigjohnson's Avatar
scored big on ebay a few months back. guys name in Washington is Rob, if you need comptech parts, he usually deals at lower prices, but you didn't hear it from me.
http://cgi.ebay.com/ebaymotors/ws/eB...ayphotohosting
Old May 10, 2004 | 08:59 PM
scalbert's Avatar
Naw, I have had my blower for well over a year and many of the other Comptech items. Outside of that I will make my own parts.
Old May 10, 2004 | 09:02 PM
Amoeba's Avatar
Best D-Line in the NFL
From: Gainesville, Fl for college, Palm Beach Gardens, Fl at Home
bigjohnson where in palm beach are u located and how old are you?
RobbDizzle
Oct 15, 2015 11:16 AM
samson_420
Oct 8, 2015 01:47 AM
thegipper
Sep 28, 2015 01:01 PM
hrothgar02
Sep 28, 2015 11:08 AM
prbori
Sep 27, 2015 01:37 AM
