O2 sensor
I've run without the catalytic at the track; check-engine light does come on after a while even if the 2nd O2 is plugged in. I wouldn't recommend this for day-to-day driving. Plus in CA they have remote laser-type smog units all over the place!
if your just trying to get rid of the restriction from the cat then just get a universal hi flow cat and get a o2 bung customized onto the hiflow cat and that should solve your problem because the o2 can plug into the hiflow cat.
Originally posted by bigjohnson
Laser this! Out of all seriousness, there must be someone with info on the modification of the O2 sensor. Don't lecture me on "I wouldn't do it because" crap. thanks in advance.
Also, you are asking questions on an open forum; do not expect filtered responses.
Thanks for your input, I guess there is no such solution to the O2 sensors. Good luck to you all.
scored big on ebay a few months back. guys name in Washington is Rob, if you need comptech parts, he usually deals at lower prices, but you didn't hear it from me.
http://cgi.ebay.com/ebaymotors/ws/eB...ayphotohosting
