No ATF refill bolt?
Old Jul 4, 2012 | 06:30 PM
Epiphany's Avatar
No ATF refill bolt?
Hey guys, I bought the fluid to do a drain and fill today and wanted to check to make sure I could get the refill bolt off before draining as I've read that it can be near impossible without an impact wrench to do. However I have found that I do not have the bolt seen in this video: http://www.youtube.com/watch?v=YceQY...ailpage#t=128s. Where that bolt is I have what appears to be a hose. Attached is a picture of my engine bay, excuse the filth. No ATF refill bolt?-v1qw8.jpg Is there something else I should be looking for instead of that bolt?
Thanks.
Old Jul 4, 2012 | 06:38 PM
Aeo12CL-S's Avatar
I looks like you have a transmission cooler hooked up that bolt hole.
Old Jul 4, 2012 | 07:36 PM
gnuts's Avatar
3.5 psi
can't you use the ATF dip stick? That's what i did for my 6speed. Get a small tube and a funnel and pour slowly into your dip stick.
Old Jul 4, 2012 | 07:59 PM
Karanx7's Avatar
Unregistered Member
It's right there. You're looking right at it. Just remove that 10mm bolt, pull out the ATF injector, and pour in ATF.
Old Jul 4, 2012 | 11:28 PM
Epiphany's Avatar
Are you talking this one? If so why is it different than the one in the video? No ATF refill bolt?-axbqy.jpg
Old Jul 4, 2012 | 11:51 PM
Karanx7's Avatar
Unregistered Member
No, not that one. The one to the left of it. In the picture, it says 12 on it.
Old Jul 5, 2012 | 03:56 PM
fsttyms1's Avatar
No its the one just to the left of that one with the rubber hose coming off of it. Yours looks different because your car has had the recall work done to it and had the Oil Jet installed. Just remove the small bolt that holds itdown and pull straight up. That is your fill hole. You cant hurt the oil jet or install it wrong.
Old Jul 5, 2012 | 03:58 PM
fsttyms1's Avatar
6 speeds dont have diptics.
And why would you pour it in there when its so much easier and faster to just fill it through the actual fill hole?
Old Jul 5, 2012 | 04:06 PM
gnuts's Avatar
3.5 psi
come to think of it that is how i filled it. (it was a like 2 years ago). I think i did use a tube to make pouring easier though.
Old Jul 5, 2012 | 05:31 PM
CL-S progression 01's Avatar
lowrd on tein CS biatch
on AT acura installed the jet kit in the place of the ATF fill bolt.
that thing with the bracket that says 12 on it is the jet kit which sits in the atf fill bolt spot..
unbolt that sucker with a 12mm i believe... maybe 14mm i don't exactly remember. then u'll have to give a good yank on the jet nozzle to release it from its position.
don't worry it's strong so it's not gonna break by yanking on it.
i ended up removing the jet kit altogether because acura put it there to prevent catastrophic 3rd gear failure. that jet kit actually takes fluid away from the 3rd gear clutchpack which is the MAIN problem with these cars. my clutch packs went 2xs on me so i decided to say F the jet kit so i get more flow/pressure going to everywhere else.
the jet kit drips fluid on the physical 3rd gear itself to prevent it from shattering causing violent stops and that's how acura got sued and the reason why the jet kit was put it.
this in turn just led to more 3rd clutch pack failures.
i just added a cooler and removed the jet kit which is the proper more expensive way of fixing the issue.
Old Jul 7, 2012 | 12:34 AM
Epiphany's Avatar
Are new washers required for the change?
Old Jul 7, 2012 | 01:02 AM
Karanx7's Avatar
Unregistered Member
Should you use new washers? Yes.
Are they required according to the service manual? Yes.
But no srsly? No, not really. It'll be fine with the old one.
Old Jul 7, 2012 | 08:12 PM
washers?? where
the atf fill bolt has a washer u will need to buy.
the jet kit has an o ring which u do not need to replace... i never did all the times i changed my fluid prior to removing it completely
Old Jul 7, 2012 | 10:29 PM
Epiphany's Avatar
Did the deed today, absolute ton of metal on my drain bolt, not too happy about that. Trans does seem to shift smoother now though. Unsure if that's a placebo or not though.
Old Jul 8, 2012 | 11:44 PM
its usually noticeable the first time u change the fluid out after its been in there a bit
Old Jul 9, 2012 | 11:42 AM
fsttyms1's Avatar
You have a LOT of mis information here. The oil jet has nothing to do with the 3rd gear issue. It is for the 2nd gear shaft. It also does not take away fluid from3rd gear clutchpacks, nor does it lead to more failures. Also adding a trans cooler is not the proper way of fixing the issue nor will it help. The issue is internal and has to do with not enough fluid being able to get to the 3rd gear drum assembly. Adding a cooler wont help this.
Old Jul 9, 2012 | 01:52 PM
just relaying what i was told 500days ago about the jet kit, i may have switched some facts around its possible, i didn't think i had orgotten but maybe i did..
and there is a LOT of opinionated facts based on this knowledge. I can tell you what i have done to my car finaly works after much trials and tribulations. so i kinda have to abide by what i've done.
Old Jul 9, 2012 | 10:26 PM
fsttyms1's Avatar
Yes there are opinionated facts, mis-information, guesses, and factual statements out there. The info i posted is factual. I went thru 5 trans, rebuilt one myself and have physically seen the damage. I also went thru 4 trans WITH a trans cooler. Simple fact is is its an internal issue. Sure cooling helps the overall trans health, but it does nothing nor addesses the issue of getting fluid to the clutchpacks for 3rd gear
tsx_boy
Dec 13, 2019 08:33 PM
spudweb
May 22, 2016 02:39 PM
hashbrown
Sep 29, 2015 12:13 PM
hpfiend
Sep 27, 2015 06:59 AM
ROSSARONIE
Sep 22, 2015 11:46 AM
