newbie
Old Oct 18, 2009 | 06:52 PM
agt's Avatar
agt
7th Gear
newbie
hello everyone newbie here from Chicago suburbs.
had the 2003 acura CL - S for a year now...
bought it and then my mom needed a new car so i made her a present. but she drives a lot and time for her to get a newer car so I am thinking of reclaiming the coupe instead of selling it. -- because no one knows these cars and i like it.
Wanted to say HI and ask some questions.
1. are there any cheap aftermarket taillights -- she cracked the driver and it might be cheaper than buying OEM.
2. what tires you guys suggest for all year --- Chicago winters.
3. suspension is creaking a bit -- i dont know if it a problem or i am just paranoid -- any known problems with those.
Old Oct 18, 2009 | 07:20 PM
Rajca's Avatar
wham bam thank you ma'am
welcome fellow Chicagoan. check out the regions, as we have 2 upcoming meets.
no aftermarket tail light, either black market or dealer. as for tires. i run goodyear or michelin (not the factory tires that come on the car, those are garbage) all season and they work good.
where is the creaking coming from? front rear. might be sway bar bushings
Old Oct 18, 2009 | 09:31 PM
stlswagger's Avatar
Old Oct 18, 2009 | 09:32 PM
stlswagger's Avatar
Welcome though lol
Old Oct 18, 2009 | 10:40 PM
madmuzik09's Avatar
Waits for Shakira in his
Welcome and how the Beep are you lol yea raja said there arent any tails for our cars unless you custom make em like nf3d0149ab did which i must say are very bad ass !!!
Old Oct 19, 2009 | 07:35 AM
CL-S progression 01's Avatar
lowrd on tein CS biatch
I had the creak going over decent bumps. So i popped the trunk and stood on the edge of it and bounced the car up and down up and down. and the creak would come.
It was a sway bar end link.
I got moog links and the progess RSB, and now no problem.
Accept the bushings lose their grease then start to squeak. But just blast some white lithium grease on there and problem solved
Old Oct 19, 2009 | 12:45 PM
agt's Avatar
agt
7th Gear
sorry i have no idea how to post pics in the thread -- nothing exciting black on black with stock rims and stock spoiler.
the creak sounds like its coming from the front driver side --- and its at low speed or when i sit down into the car -- my guess it might be the wheel arm
i dont know where the local meet threads are but will look for them
Old Oct 19, 2009 | 12:53 PM
agt's Avatar
agt
7th Gear
my mom was in an accident before and took it over to Gerber autobody -- and i suspect those guys installed used parts
Old Oct 19, 2009 | 05:42 PM
Rajca's Avatar
here u go
https://acurazine.com/forums/chicago-313/
check the bushing to make sure that they are in good condition. and not torn.
not the safest way to do it but it will work
take the wheel off, put a jack stand under the control arm. while u press on the fender or the radiator support bar, have someone look at what squeaks. spray some wd40 or pb plaster on what u think is squeaking and see if it goes away.
Old Oct 19, 2009 | 05:43 PM
princelybug's Avatar
LIST/RAMEN/WING MAHSTA 짱
agt, post pics!
BTW, welcome!
Old Oct 19, 2009 | 11:17 PM
n0rm's Avatar
I ♡ PEK PEK
Originally Posted by princelybug
agt, post pics!
BTW, welcome!
Old Oct 20, 2009 | 12:13 AM
civicdrivr's Avatar
Welcome!
Old Oct 20, 2009 | 11:01 AM
i would have to agree with taking the wheel off.. put something under the car on something sturdy that doesn't move. OBV lol.
then take a jack and put it under the rotor and crank it and see if u can get it to make the noise. Make sure to be careful with the rotor... I'd put a cloth between the jack floded a few times to make sure there is no damage (assuming you don't have the rubber piece on ur jack)
I'd just lithium grease EVERY MOVING joint in there and then see if that solves it.
My money is still on the end link.!! HIGHLY.. when mine would squeak it did it when the car moved slightly.. not aggressively.
It's the little bit of movement that creates that noise. Get some Moog end links for 60$ have em installed for 40.. and that should be ur fix.
I'd start with sparying everything with lithium first (the more the marrier) tho cause that'll show u if it's NOT the end link.
Or it may be the spring creaking. how many miles on the car?
Old Oct 20, 2009 | 03:48 PM
agt's Avatar
agt
7th Gear
thanks all ---
i am not that concerned but will have to look at it.
I need to get new tires on it for the winter -- suggestions (not performance just all year around).
Old Oct 20, 2009 | 03:49 PM
agt's Avatar
agt
7th Gear
i drove the car and was a bit concerned it pulls to the side --- not a lot barely noticeable --
added air to the tires because thats usually the simplest stupid thing --- so I'll see.
Old Oct 20, 2009 | 04:16 PM
GOOD YEAR TRIPPLE TREAD ASSURANCE..
best tires in the rain period.. got a 220 KM/H speed rating, GREAT tread wear life, and they are grippy in the snow or asphalt PERIOD. I am buying a set actually this saturday. 200 a tire, and they are worth every single penny
Old Oct 20, 2009 | 06:10 PM
Rajca's Avatar
Originally Posted by agt
thanks all ---
when u get a chance pm me. i have a good hook up on tires.
Old Oct 20, 2009 | 09:01 PM
agt's Avatar
agt
7th Gear
rajca -- as a new user I do not have access to PM..
pretty weird - if u ask me
Old Oct 20, 2009 | 09:11 PM
Rajca's Avatar
i know, thats why i said when u get a chance. start posting up in ramblings.
Old Oct 20, 2009 | 09:19 PM
hahah you link me that tire deal... you got shipping dealls TOO... jks
Old Oct 20, 2009 | 09:38 PM
Rajca's Avatar
its better than half of what the set costs. but no shipping. u come to me.
Old Oct 20, 2009 | 09:47 PM
agt's Avatar
agt
7th Gear
rajca just email me:
atsinman -at- yahoo(dot)com
greeneyes.hypnotize
Sep 27, 2015 02:47 PM
DunesCreations
Sep 9, 2015 12:03 PM
n2booz
Sep 28, 2004 05:35 PM
spankin-cl-s
Aug 12, 2001 05:40 PM
