New Supercharger Pulley
Old Apr 9, 2004 | 09:33 PM
scalbert's Avatar
I got back in town from DC late last night and was not aware I had received a package until this morning. As soon as I saw it I knew that it was my new pulley but I didn't get a chance to put it on until this evening.
Below are pictures of the new and base Comptech SC pulley. The overall diameter is not significantly different but the value we are shooting for is measured at the top of the ribs. This new pulley has taller sidewalls which reduced the apparent size difference. I went from the 3.8 Comptech base pulley to the new 3.5 unit. I am also running the HBP (alternator pulley).
I only went for a quick run as I was needed at home but the initial impressions are good. Boost ran up to about 7.5 PSI quickly and I wasn't fully into it. I suspect that a little over 8 PSI will be the maximum as expected. Power was great but not fully explored. But what I was really looking for was immediately seen; the A/F ratio went to the low 13's at near WOT. 13.1:1 and 13.2:1 were the average values during the quick and not quite WOT runs I made.
Probably the most interesting part is that I did not hear any knock at all. Even though it was going leaner the engine had no audible knock. That is a true testament to using an intercooler as opposed to not using one.
I came back and hooked up the e-Manage software and added 10% pulse width addition from where I was currently at. This should bring me back into a safe A/F ratio. I also added back in some retard until I feel safe about the fuel supply. These will be adjusted through the following week and hopefully in time for a new dyno session next weekend.
As a side note I also tested the bleeding function to lower the fuel pressure. I determined that a 0.125 bleed is needed with a one foot distance off the additional port on the FPR; more on that later.
Below are pictures of the new pulleys along with newer pictures of the IC installation:
Old Apr 9, 2004 | 09:37 PM
Pull_T's Avatar
What A/F are you shooting for?
Old Apr 9, 2004 | 09:43 PM
scalbert's Avatar
To be safe with the stock 10.5 CR, I want to stay in the 11.5:1 - 12.0:1 A/F ratio. It may be a bit richer than needed and I will adjust it if needed. But for the time being I'd rather side on the rich side for a good comfort margin.
Old Apr 9, 2004 | 09:49 PM
allmotor_2000's Avatar
Good job Steve!
I wouldn't recommend driving around too much at 13.x A/F. At least don't get on it for extended periods of time - although its not going to harm the motor, it does allow for excess combustion-chamber temps.
Anyways, it should post good #'s on the dyno - 370 to 380whp is my guess; do you know how much your S/C flows at its new-found velocity?
Old Apr 9, 2004 | 09:58 PM
scalbert's Avatar
Thanks Ramanan,
That is why I went back and added pulse width in the e-Manage. This should richen it more than needed but I will see for sure tomorrow.
We'll have to see about the power numbers and I would be happy if your assumtion is correct. This new manifold design does seem to flow better at the higher revs. The shorter and straighter runner path is probably the reason.
As for flow numbers on this blower. I suspect that it should be at least 550 CFM (maybe upwards of 600CFM) based on the data from the Magnuson's website. The blower should be turning at over 16,500 RPM near redline.
http://www.magnusonproducts.com/mp62.htm
Old Apr 9, 2004 | 10:07 PM
MtBikR's Avatar
Just pruely awesome!!
Old Apr 9, 2004 | 11:15 PM
darrinb's Avatar
///M POWER
nice work steve, good luck on launching at the track
i know atlanta dragway is high and humid but at sea level under normal conditions what do u think is possible??
Old Apr 9, 2004 | 11:55 PM
Smitty's Avatar
.... I am getting all excited here....awaiting your seal of approval.
Old Apr 10, 2004 | 02:01 AM
Chopsie's Avatar
Beware of leakage
Re: New Supercharger Pulley
Not trying to sound like a moron here, but what is really different about your Motor, besides the obvious S/C and Intake. I guess I haven't seen other pics of your engine bay, but doesn't look like other S/C 3.2's I've seen. Just curious.
Old Apr 10, 2004 | 06:19 AM
scalbert's Avatar
With who driving??
Old Apr 10, 2004 | 06:22 AM
scalbert's Avatar
Re: Re: New Supercharger Pulley
The current differences are that I mounted the reservoir but I don't think that is what you are referring to. The manifold is completely different which includes the IC. Below is the stock manifold with the SC:
Old Apr 10, 2004 | 06:49 AM
scalbert's Avatar
I just got back from another test drive and the A/F ratio is back at where it should be. The power was also impressive making tests in 2nd worthless. 3rd was pulling strong with no knock present. 4th will be the tell all for the knock aspect but I won't get to try that until later on the highway.
I'll test it out through the week and hopefully make it to the dyno next Saturday. If things pan out then I may try to go to Atlanta Dragway the following friday (the 23rd) for some times.
Old Apr 10, 2004 | 10:06 AM
ferizzo's Avatar
still a Masshole
I hate you for torturing me every time I read your posts! I learn a little reading them but hate you because I want all these things!
great job and nice hearing about the awesome results!
Old Apr 10, 2004 | 01:05 PM
darrinb's Avatar
///M POWER
With who driving??
me
Old Apr 10, 2004 | 01:21 PM
scalbert's Avatar
In light of recent events I may have to pass on that one.
We'll see what I can pull off soon...
Old Apr 10, 2004 | 02:30 PM
In that case, maybe I need to find an excuse to make a business trip out there!!
Old Apr 10, 2004 | 03:05 PM
scalbert's Avatar
Come on out, I need a good driver behind the wheel.
Old Apr 10, 2004 | 03:36 PM
Ray Khan's Avatar
hey Scalbert...awesome work man! Anyway to incorporate a knock senor with your engine and with EManage? Just because you can't hear knock doesn't mean there isn't any right? It's great to see people going the extra mile. Keep up the good work, can't wait to see the power numbers.
Old Apr 10, 2004 | 05:22 PM
scalbert's Avatar
Unfortunately no, there is no knock sensor input for the e-Manage. I may end up using an external knock monitor but haven’t decided yet.
I agree, hearing it isn’t everything. But we have to start somewhere and I am using the old fashion method; go until you hear knock and then back off a safe margin. The problem is that it keeps one from running closer to the edge.
Old Apr 10, 2004 | 05:25 PM
Steve... stop screwing around with your car; arn't you forgetting you need to 'test' something this weekend??? :wink:
Old Apr 10, 2004 | 05:46 PM
scalbert's Avatar
heheh. I was waiting on that.
That is on the Sunday night in the basement schedule.
Old Apr 10, 2004 | 05:50 PM
Are you planning on doing a 'live' test, i.e, on your car?
Old Apr 10, 2004 | 06:49 PM
scalbert's Avatar
I was seriously considering it and will try it time is available. The problem is that mine is a bit of a pain to take out since there is too much cable. I have to take the glove box off. But I want to clean up, e.g. shorten the cables, so this might be the time to do so.
Old Apr 11, 2004 | 10:21 AM
ModAddict's Avatar
What are you working on now Steve?
Did you see they're having problems with the Loteck pillar pods on the TL's. The credit card I gave them expired and they didn't ship mine, so I don't know this first hand.
One thing that I keep wondering about with the IC is the EGR plumbing. On mine there are passages built into the intake going thru the intake runners. Is that different from yours?
Old Apr 11, 2004 | 10:37 AM
Fast Gold's Avatar
Any plans on dynoing the car?
Old Apr 11, 2004 | 04:26 PM
scalbert's Avatar
PnP harnesses for Ramanan.
Yea, I saw that and am trying to figure out what went wrong. Thankfully only a few TL owners ordered them.
There is an EGR port in the manifiold base; that part was easy.
Old Apr 11, 2004 | 04:27 PM
scalbert's Avatar
Old Apr 11, 2004 | 05:42 PM
ModAddict's Avatar
Very cool! E-Man for the Turbo-Man.
I'm sure Loteck will refund, and resell them soon.
I can't believe I didn't see that one comming! That was too easy. :o
Old Apr 11, 2004 | 07:54 PM
Black CL-S 4-Life's Avatar
Floyd Mayweather Jr.
Can't wait to see those track times.
Old Apr 11, 2004 | 08:44 PM
Actually two!!
Old Apr 11, 2004 | 10:08 PM
ModAddict's Avatar
Actually two!!
Someone else is joining you on the dark side eh!
Old Apr 11, 2004 | 11:59 PM
Yup, two this time (BlueCLS6)
Old Apr 12, 2004 | 07:37 PM
BlueCLS6's Avatar
ex 6 Speed owner :(
Yes I too am involved in this long process of custom fabrication...
But the result =
Old Apr 12, 2004 | 08:33 PM
scalbert's Avatar
BTW you two, I had to redo a part of the harness. I'm working on it right now and my fingers are hurting. :o
Old Apr 12, 2004 | 08:35 PM
You are on the computer... how could you be working on the harness???
Thanks for all the work Steve!! I'll inscribe your name on the E-Manage
Old Apr 12, 2004 | 09:30 PM
SLY1TYPES's Avatar
Not Fast Enough
Hey Scalbert
Wow good work, what times and mph are you hoping for?
What tires do you have for all that BIG power!!
Thanks,
KEvin
Old Apr 12, 2004 | 11:08 PM
darrinb's Avatar
///M POWER
what requirments do u need at the track for a car in the 12's
Old Apr 12, 2004 | 11:09 PM
mattg's Avatar
helmet
Old Apr 12, 2004 | 11:18 PM
darrinb's Avatar
///M POWER
oh, then 11's is rollcage??
Old Apr 12, 2004 | 11:21 PM
mattg's Avatar
i think so
