New Comptech Headers In, J-Pipe Problem
hi all,
re: 2003 CLS6
i was planning on doing a full write up of a bunch of mods I am have just completed and results (p2r test pipe, option pulley, CT headers, custom cat-back, etc) but i have a small issue that my mechanic just advised me of.
I just (a few hours ago) received my new CT headers. This batch was just completed a few days ago and I purchased direct from CT. My mechanic just pulled off my factory j-pipe and called to tell me the new CT j-pipe is 4-5 inches shorter than the original j pipe. This is really odd considering CT's reputation.
I will call them in the morning but I just really doubt they would manufacture a batch with this major issue. The CT box says they are for the 2003 CL 6 speed (in fact, i think all their V6 headers except for the NSX are the same ones with the kink).
Has anyone else had this issue?
My solution:
I am doing a full mandrel cat back immediately after the header install just like nupe's on the advice of P2R. With that being the case, my work around will be to simply bolt my test pipe to the CT j pipe and then build my cat back from the rear of the test pipe and all will be well except for the embarrassing drive to the exhaust shop from the mechanic.
I am still having trouble believing the CT j pipe could be that much off in length... could it be they made it too short.
I will post a follow up when this is resolved...
re: 2003 CLS6
My solution:
just a follow up...
when you lay the factory j-pipe next to the stock one, are they different lengths? I think when its all bolted up, perhaps the difference in mounting locations accounts for the difference between the two... at any rate, I will have answers tomorrow...
Moderator Alumnus
I did comparisons too before I put headers on my CL. The aftermarket headers are definitely longer and noticeable too.
The J-Pipe is supposed to hook up to the OEM cat with no problems.
it seems the mechanic was implying that the overall length of the j-pipe (rear most flange that bolts up to cat <---> front of j-pipe) is not the same length as the stock j-pipe. In other words, the CT unit wont make it all the way to the front of the cat....
i'll post the outcome soon....
lowrd on tein CS biatch
HELLO... he said the J pipe is 4-5 inches shorter because the HEADERS are 4-5 inches longer than the stock ones.
Obviously the j-pipe standing on it's own will have shorter pipes running to the motor.
Mechanic must of had a serious brain fart
Why do you have a PIC of DC sport headers??? why did you to comptech if you don't mind me asking.
I've been trying to see the pros and cons between the two for some time now, I'd appreciate some insight.
SidhuSaaB
05-30-2020 12:40 AM
