New axle time
3.7L Nitrous Breathing CL
Napa.
Since you did not jumble napa in with all the other brands you already know where you should spend your money.
I bought these cheap ones in april 2010 and they are still ok.
Knock on wood.
http://cgi.ebay.com/ebaymotors/Drive...Q5fAccessories
Knock on wood.
Whats up with RDX owners?
I went with Auto Zone axles. So far so good, and theyve been in there for about 10k so far, maybe more (I can't keep track of mileage anymore).
http://www.raxles.com/default.aspx
Its not hard if youve swapped axles on other FWD cars. The most annoying part was separating the ball joints.
raxles are overrated, i had a set but they eventually tore at the boot from normal driving and they wouldnt warrant it. so much for a lifetime warranty...
ive gone through a few autozone axles, you'll get the occasional shitty one (vibrations at certain speeds), but you can take it back and swap it out. it just sucks that you have to spend time removing it.
https://acurazine.com/forums/2g-cl-problems-fixes-70/oem-verses-oe-axles-788138/
As a result, I googled raxles and turned up more positive then negative regarding their quality.
fuzzy, if you want to get the local retail axles, go for it. If you want to keep your money in the local economy, for the extra money, these are a viable alternative, to each his own.
I know oem are the only axles I've seen that have the damper on them.
Any time you can take vibration out of rotating parts they will last longer.
I don't think the oem axles would last any longer even at the joints if they didn't have the dampers.
They still snap.
When will the cheaper axle company's be a little more competitive with the oem and come out with the damper designed axles
They still snap.
They still snap.
They still snap.
Advance Auto axles have the damper as well.
Its a big ass round rubber disc on the passenger side axle IIRC, you cant miss it.
http://www.youtube.com/watch?v=ISY8bGof3bQ
Received 1,080 Likes
Fuzzy, one of my CV joint boots just ripped last week. 175,000 miles on the original ones.
I just picked these up over the weekend. Have not had a chance to install them.
http://shop.advanceautoparts.com/web..._841279087____
Yeah, I believe you called them 'junk' in the thread below.
https://acurazine.com/forums/showthread.php?t=788138
mine ripped at the boot, so i figured, why not use my lifetime warranty... but apparently there are a bunch of situations where the warranty isnt honored and ripped boots are one of them.
fyi i dont beat the crap out of my car nor drive it every day.
IMHO, for the folks making power... go to the driveshaftshop. for the folks looking for an oem replacement, go to your local autozone/napa/advanced auto.
Nor do I.
Noted.
justin7779
12-25-2015 10:33 PM
