Need info: Tansmission fitments
The transmission in my 01 CL-S is on its last leg and I would rather not replace it with the same junk that came with it. I found an auto trans from a 07 TL from the j32a3 motor and I would like to know if it would bolt up or have any other fitment issues that anyone might know of. Thank you in advance.
J-series addict
Since it on the board, what's the biggest difference internally between the 2004-2006 transmissions that mount up to the J32A2? Out of the TL, Odyssey, and Accord, which one has the highest potential for power handling capabilities? Can the 04-06 TL auto be installed as a "plug and play" or not? I've heard there are a few sensors that must be exchanged but other than that? I'm questioning the integrity of the 5-AT from an 03 TL-S I had rebuilt (that had NO previous issues before removed) will actually handle 600-700hp nitrous hits. Just need to know the best choice.
Chapter Leader (Southeast Region)
J-series addict
So 05-06 would be optimal for strength and reliability then?
I've read somewhere that the issue on these autos is due to an inadequate amount of fluid to critical area/component and that's why adding an external cooler does nothing to prevent transmission failure from occurring. I must say (knock on wood) that I've had very good luck in running Amsoil synthetic ATF while pumping out 500-550hp on this 5-AT tranny. It's taken a pretty severe beating indeed. The car itself has currently around 136,xxx miles and the original transmission was replaced a little after 50k miles by the dealer as mentioned by a parts associate at my local Acura dealer who ran my VIN to check on recalls for me. I bought the car with 103k miles. That means the transmission itself has some 80k+ miles on it...20k miles of which were all during heavy nitrous use. Correct me if I'm wrong here but it seems to me that the whole issue with our transmissions can be either corrected or delayed (hard to tell) by simply running a higher quality fluid (I've ran ONLY oem Acura DW1 and Amsoil) and by changing the fluid very frequently. I personally drain and fill the ATF usually within 1000-1500miles. The only reason I've refused to put an aftermarket cooler on is because I'm afraid that the added length in line (maybe 6-8ft) and the cooler itself (restrictive design) would surely decrease fluid pressure not to mention add to the starvation issue within the transmission itself. I am merely guessing and making assumptions here but like they say: if it ain't broke...
J-series addict
Holy cow man, talk about having some car troubles. I myself have seriously contemplated the 6-spd swap as well. The biggest reason being because I can do all the work myself here in the shop and take my time with it so that it's done correctly. I'm not to savvy with all the swap parts available but I do know that there are harnesses available that allow us to run the automatic powertrain wiring with the 6-spd so I'm confident I could find out how to do that without having to spend the money on the harness. My biggest obstacle here would be the conversion from the inside of the car...I have very little fabrication skills/experience when it comes to this but doesn't look all that challenging from what I've seen. I know I will more than likely end up using the AEM standalone for the 3.5 build anyways due to the cams and ignition modifications required to run high levels of nitrous so I might just do it all when the motor gets replaced. I have others I'm sure would be willing to assist in the areas I can't do...or just choose not to do.
Might as well save ourselves the trouble with these auto's and just do the swap. Haha.
^ other than the tranny, it's been a great car and this is the first one I'm going to have to replace. I was about to drive it up to va for the 6 speed swap until it got to the point where I can't drive it. I don't really have the time, knowledge, or tools to do it myself. I use the car everyday so I can't leave it sitting for months trying to do it because it is my only car. When this one starts to give me any signs of trouble I'm going to drive it up there to have it done since none of the shops around me want anything to do with swapping parts. By the way te guy that makes those harnesses has been MIA and nobody lately has been able to get one on this board.
MrHeeltoe
79
10-14-2015 08:47 AM
adreano17
09-29-2015 08:48 AM
nuldabz
09-03-2015 05:49 PM
