A Navigation touch screen PEN... for our navi's
Old Mar 31, 2003 | 01:27 PM
LiLMaN's Avatar
I was wondering for our navi's has anyone tried using those pens used on the palm pilots? Just wondering because tired of fingerprints and keep cleaning it... so if the pens work I would rather go that route since its more easier to click on the buttons with those pens and also cleaner.
Old Mar 31, 2003 | 01:38 PM
Slimey's Avatar
Where is my super sauce?
It's just a swipe with the included microfiber cloth once per week or so. What's the big wup? I'd hate to fumble for a plastic wand every time I wanted to use the Nav.
I know it's not the answer to your question though -- just my $0.02. I also cannot imagine that the dealer will be happy if (for some reason) you had to replace the screen and there were a ton of scratches or pits on it.
Old Mar 31, 2003 | 02:07 PM
LiLMaN's Avatar
Scratches? How would you get scraches if your just pressing the screen lightly and you can use the joystick for other movements consisting of upward or downward movement on the mapguide screen.
Old Mar 31, 2003 | 02:36 PM
mt6forlife's Avatar
Have you seen the grafitti area of a Palm? Lots of scratches. The stylus picks up dirt and it acts like sandpaper.
Old Mar 31, 2003 | 10:11 PM
eighteight's Avatar
i could be wrong but i believe the navi touch screen works from the heat on your finger, not the pressure. If you notice you dont have to even touch it, if you just get reallllllllll close without touching it it usually works. So unless you got a hot palm pilot pen, im not sure it would work anyway
Old Mar 31, 2003 | 10:38 PM
kensteele's Avatar
You are 100% correct. A stylus will not even work.
Old Apr 1, 2003 | 02:38 AM
AcuraTLSFan's Avatar
Registered Member
HEHEHE.. Touch screens don't work by the principles of Heat or Pressure. They are either Resistive or Capacitve touch screens. When you touch the screen it will change the resistance or capacitance value at that curtain location, then the computer takes that locations address and activates that (X,Y) coordinate.
Old Apr 1, 2003 | 06:11 AM
soopa's Avatar
The Creator
you mean you dont wear white gloves when you drive your car?
Old Apr 1, 2003 | 06:56 AM
Juker008's Avatar
TRELOS
AcuraTLSFan,
I believe that u are the more correct person.
But I always thought that it worked by light. When u touch the screen u blacken out an area on the screen. Then the Navi computer recognizes that area and computes for it. I'm just thinking in the way that my B&O system works.
Soopa,
Funny .
Juker008
Old Apr 1, 2003 | 08:31 AM
Stock03CLS's Avatar
A stylus will not work on these screens. I've tried. No luck.
Besides, touch screens that can be used with a stylus are usually harder/more rigid than those that are designed to work with one's fingertip. Using a stylus on a softer screen like that could make little dents in addition to the scratching that can occur from a stylus.
Old Apr 1, 2003 | 09:29 AM
phil2's Avatar
has Gloryhole Girls in
classless fools :P
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
navtool.com
Sep 25, 2015 05:15 PM
TL14
Sep 24, 2015 04:37 PM
