Mystery Oil leak where teh heck is it coming from?
Blown is Best
If it's dry between the engine and tranny, it may be coming from up higher on the motor. Check your valve covers and cam plug areas. I had a problem isolating the source of one leak and we ended up throwing some dye into the motor and using a black light to find the source.
Then a few days nothing and it just stayed a bit moist on the transmission for a month.
Then some more small drips at which point I searched, saw the main seal threads, opened the access and dry as a bone.
Last week I did another oil change (I drive alot) and after a 380 round trip to lovely Yuma a slightly smaller puddle then after the Vegas trip.
I have looked at the area between the head and block and see nothing.
On a related note, I have no transmission issues, but although it seems fine should I treat the torque converter like I would a clutch & replace it for peace of mind if I end up pulling it?
I have done that at least 10 times with this:
http://fenixgear.com/store/viewItem..../img/L1DQ5.jpg
Getting sick of jacking it up.
All I see is what appears to be oil coming from the top of between the engine &
transmission, open the access to the TQ & dry as a bone.
It was on a lift yesterday having the axel boots replaced and I looked for almost an hour.
cycdaniel
12-17-2019 10:58 AM
IIDXholic
10-08-2015 07:53 AM
Marmbo
4G TL Problems & Fixes
09-21-2015 09:39 AM
winkyyy
09-11-2015 04:40 PM
02, acura, acurazine, cl, httpfenixgearcomstoreviewitem, is350, leak, mdx, mysterious, mystery, oil, rdx, small, tl, transmission
