My dash light is a little dark...
Old Jan 31, 2008 | 10:19 PM
badeh2's Avatar
sIx SpEeD
So, i woke up this morning and turned on my car and the section where it tells you your mileage is a little dark... Did a bulb go out? fuse? Its not COMPLETELY DARK that i cant see but its a little darker than it should be... help a brotha out guys.....
Old Jan 31, 2008 | 10:55 PM
distortedolskool's Avatar
i'll take burnt bulb for $100.
the light is probably filtering into that area from the others.
Old Jan 31, 2008 | 11:40 PM
badeh2's Avatar
sIx SpEeD
u'll take my burnt bulb for 100 dollars???
Old Jan 31, 2008 | 11:45 PM
TOPHER33884's Avatar
LMAO.....No bro, he means he will bet $100 bucks that its a burnt out bulb!
Old Jan 31, 2008 | 11:46 PM
jeopardy reference.
but seriously i bet it's the bulb. really no explanation for the dimness. only other thing that would make the bulb dim would be a voltage drop (not really possible & highly unlikely) or the bulb is burning out.
Old Jan 31, 2008 | 11:52 PM
badeh2's Avatar
sIx SpEeD
LMAO... dude TOPHER i was at harris teeter 2nite and saw ur car, where da heck where u though... i only saw MADHU's ass. lol
Old Jan 31, 2008 | 11:53 PM
badeh2's Avatar
sIx SpEeD
so how hard is it to change a bulb?!?! i bet its a pain in the ass to try to get into the dash...
Old Jan 31, 2008 | 11:58 PM
actually it's not bad. just 2 screws directly above the cluster and the rest just snaps out. you can get your fingers under the piece at the cluster and just starting prying around to the left and then towards the radio controls. be careful because the clips can break.
then you will see 4 screws holding the cluster in. take those out and unplug all the wires out of the back. don't worry cuz the plugs can only go in one location on the back of the cluster so there is no confusion or mixing of wires. then just pull the bulb out of the odometer and check it out.
see the 3 red knob like items at the bottom center. those are the bulb holders for the odometer. ignore my cluster fuck of wires.
view with the white cover removed. still 3 red holders bottom center.
Old Feb 1, 2008 | 12:12 AM
badeh2's Avatar
sIx SpEeD
SWEET... SIGH THIS IS GONNA BE A PAIN IN THE ASS... so, those bulbs are at advance auto parts n stuff right? i remember doin it on my 94 hatch one time, and i broke a peice and i was pissed.
Old Feb 1, 2008 | 08:08 AM
Moodist's Avatar
I had a bulb go out in the dash, dealer covered under warranty. One thing they suggest thought, is one you replace one burnt out bulb, replace all of them. Something about how the rest of the bulbs are likely to burn out also.
Old Feb 1, 2008 | 02:00 PM
GreenMonster's Avatar
As long as you're sure you didn't hit the dimmer switch on the dash lights, it's probably just a bulb.
Old Feb 1, 2008 | 02:08 PM
'01White3.2CL's Avatar
TellinItLikeItIsSince1/06
Originally Posted by GreenMonster
As long as you're sure you didn't hit the dimmer switch on the dash lights...
what i was orginally thinking...does sound like the one bulb is out tho from what you say.
Old Feb 1, 2008 | 02:11 PM
badeh2's Avatar
sIx SpEeD
hehe, no i didnt hit the dimmer switch, i was actually messing around with them... but, i do remember the night before, i hit the top of my dash pretty hard because me and the gf were having a fight... so i tried hitting it hard again, but the lights still stayed the same. I felt guilty afterword... my poor car goes through so many things... lol
Old Feb 1, 2008 | 02:40 PM
gaping46and2's Avatar
SOLD: 03 SSM CLS Auto
Probably the shock from hitting the dash cause one of the bulb's filaments to break, resulting in the burned out bulb. It's not very difficult to replace, just don't rush or force anything and you'll be fine. You won't have to disconnect the cluster from the car even. The bulbs are #74, which can be found just about anywhere that sells automotive bulbs.
Old Feb 1, 2008 | 06:45 PM
mohaukachi's Avatar
upgrade
on a related note... is there any way to fuck up the readout of the tachometer while your in there?? i bought my cl used and the damn thing reads 1500 rpm slower (means redline is 5500) ive gotten used to it but ive noticed a light out under my 9k rpm area so if theres a way to fix both id love to know about it!
Old Feb 1, 2008 | 07:11 PM
Figured I'd mention it... sometimes we luck out and it's something simple...
Looks like you'll be taking your dash apart...
Old Feb 1, 2008 | 09:25 PM
jproy's Avatar
MP90 uninstalled
That is odd your tach only goes to 5500rpm. I wonder if you have something else going on you dont know about. If your ECM thinks your car is not moving It will limit the rpm to 5500rpm. I know it does that on the autos if you are not in drive, but you have a 6mt. So do I and I dont ever remember not being able to rev past 5500rpm at any time. That would drive me nuts.
Old Feb 2, 2008 | 02:33 PM
mohaukachi's Avatar
upgrade
i thought of that... a scan tool reads the correct rpms! go figgure! maybe its the gauge itself
Old Feb 2, 2008 | 04:16 PM
jproy's Avatar
MP90 uninstalled
weird. That would really drive me crazy.
mada51589
Jan 9, 2025 04:40 PM
BoricuaTL
Apr 8, 2016 01:08 PM
Rob144
Sep 21, 2015 08:18 AM
Greengecko
Sep 16, 2015 08:19 PM
PortlandRL
Sep 14, 2015 12:01 PM
