Mr TL or SilverKnight ? on shock sensor
Old Jul 11, 2001 | 02:53 PM
spiroh's Avatar
Partsexpress.com has some shock sensors that I was thinking of buying. Does the shock sensor need to have 4 wires? How do you turn off the alarm when its going off?
Old Jul 11, 2001 | 03:12 PM
icy CL's Avatar
Originally posted by spiroh:
<STRONG>Partsexpress.com has some shock sensors that I was thinking of buying. Does the shock sensor need to have 4 wires? How do you turn off the alarm when its going off?</STRONG>
hello spiroh. i haven't done this shock sensor thing yet but i am assuming if you hit the unlock or lock buttons on the remote fob, it would shut of the alarm since i believe you will be tapping into the stock alarm, right.
Old Jul 11, 2001 | 04:05 PM
spiroh's Avatar
Just making sure.
Originally posted by icy CL:
<STRONG>
hello spiroh. i haven't done this shock sensor thing yet but i am assuming if you hit the unlock or lock buttons on the remote fob, it would shut of the alarm since i believe you will be tapping into the stock alarm, right.</STRONG>
Old Jul 11, 2001 | 04:09 PM
NOVAwhiteTypeS's Avatar
<STRONG>
Hey icyCL wanna join jrock, Ageancls phitl and me when we do the shock sensor? we also might add prox/motion sensors. and make it dual stage by adding a relay. Silver, was also talking about adding a siren so it makes a chirp instead of teh ususall beep when it arms.
Let me know if your in. I still havn't seen your car.
Old Jul 11, 2001 | 04:11 PM
Edub-TL's Avatar
Sticky Rice OwnZ joO
Hey Spiroh,
I was planning on getting one from that site too, the bulldog one for $8.
My buddy and I are going to put it on next week.. I believe that is a dual stage sensor (warn away) and the actual trip..
Some of the members from the TL board have wired both the warn away and trigger to one wire..
Mr tl's instructions are for sensors that are just 3 wire. You could siimply wire up the three needed and not the warn away one and it should work just fine.
Hope this helps..
Old Jul 11, 2001 | 04:13 PM
SilverKnight's Avatar
Retired. Not available.
spiroh,
Single stage sensor has 3 wire (power, ground, trigger), dual stage has 4 (with the addition of (warning trigger).
When there is a vibration, single stage sensor grounds the trigger wire while dual stage grounds warning trigger (light vibration) or trigger (strong impact).
If the security system dectects ground on one of its input wires, it goes off. To turn off, just press a button. The yellow wire I mentioned in the template is the hood input (in case the hood is popped open while the system is armed).
Hope this helps. Good luck, bro.
spiroh's Avatar
What are the effecs if u wire the warn away and the trigger together?
Spiro
Originally posted by Edub-TL:
<STRONG>Hey Spiroh,
Hope this helps..</STRONG>
Old Jul 11, 2001 | 04:17 PM
Originally posted by NOVAwhiteTypeS:
<STRONG>
Let me know if your in. I still havn't seen your car.</STRONG>
NovawhitetypeS, the siren project is negative. the security system delay time is too long. In stead of making a chirp, I got about 2 sec. of siren going off.
The dual stage trigger with the factory buzzer will drain the battery through the relay so I'll abandon it. I guess I'll settle for 3 shock sensors (hood, sides) no motion. sorry to disappoint you. Good luck with your project.
Old Jul 11, 2001 | 04:22 PM
Cee eL eS's Avatar
<STRONG>Hey Spiroh,
hey edub! when and where u planning to do this? i wanna check it out if ur gonna be in the bay area...
Old Jul 11, 2001 | 04:33 PM
<STRONG>What are the effecs if u wire the warn away and the trigger together?
Spiro
</STRONG>
the security system will go off in both cases.
Old Jul 11, 2001 | 04:51 PM
icy CL's Avatar
<STRONG>
nova...let me know when. i know i always say i'll show up but either work or the girlfriend always seem to pop up with some reason for me not to be able to go. PRIORITIES!! if you guys are doing it this weekend, i'll most likely be able to show up....but then again, it's just wednesday now. just the same let me know when and where!! thanks, nova! and by the way, my car's nothing special...compared to all yours, mines probably junk...it's just something i like messing around with once in a while!
RobbDizzle
Oct 15, 2015 11:16 AM
StevieB1503
ILX
Oct 8, 2015 04:52 AM
Boraxo
1/2G MDX (2001-2013)
Sep 29, 2015 04:35 PM
thegipper
Sep 28, 2015 01:01 PM
hrothgar02
Sep 28, 2015 11:08 AM
