spring?
Old Jul 10, 2001 | 08:26 PM
Southpaw's Avatar
spring?
do u have to replace the stock shox if u want to add lowering springs?
Old Jul 10, 2001 | 08:36 PM
dlew308's Avatar
No. Some do, some don't. The shocks may wear out faster, so some install new shocks when putting on new springs to get it other with.
[ 07-10-2001: Message edited by: dlew308 ]
Old Jul 10, 2001 | 09:04 PM
Southpaw's Avatar
thanks, i leased my cls so i don know if i iam even allowed to put them on, oh yea how much does i cost to get them installed.
Old Jul 10, 2001 | 09:21 PM
dlew308's Avatar
never heard of a lease where you can't put em on...i have a leased CL-S and i'm having em put on. you'll have to check the shops around your area for install pricing. What brand of springs you looking to get?
Old Jul 10, 2001 | 10:50 PM
Southpaw's Avatar
well i have h&r on my max, i am looking at those comptech ones they look pretty popular. see i live in nyc-long island and the roads out here suk and my max rides pretty hard with 45 tires on them, i saw a cl on here with 18 wheels and the comptech springs and it looked reaaly tight, what kind are u getting?
Old Jul 10, 2001 | 11:15 PM
fbazakos's Avatar
on bin laden
you're looking at $200 to install ... that's why i'm putting mine on myself.
Old Jul 10, 2001 | 11:18 PM
dlew308's Avatar
I have ST, Suspension Techinques, about a 2" drop...yea do em your self if possible. Just rent a spring compressor.
Old Jul 11, 2001 | 02:28 AM
Southpaw's Avatar
well out of all the springs which has the best ride quality?
Old Jul 11, 2001 | 04:06 AM
dlew308's Avatar
hard to say...i've never tried em all and they're different per car. I'd have progress and RS*R's before. Eibach seems to be the preferred choice but I'd think they'd all feel nearly the same per the amount they lower. It's all subjective and your call since you'll be driving it <g>
Old Jul 11, 2001 | 04:11 AM
langjae's Avatar
do it yourself, !
I got eibach because i didn't want to support monopolistic prices. Comptech charges an arm and a leg for stuff that's not made for our cars. But the only reason why I got their headers was because I got them for around 400 bucks.
-j
Old Jul 11, 2001 | 04:18 AM
Southpaw's Avatar
how much will the eibachs lower the car, i know they are great for performane.
Old Jul 11, 2001 | 05:07 AM
Chris's Avatar
- daemonichris -
no... but eventually you will have to.
Old Jul 11, 2001 | 05:29 AM
SLVRTSUNAMI's Avatar
the Eibach pro kit springs (they are the Accords BTW) wilol give you a little raked stance at about 1.5-1.75" up front and about 1-1.5 in the rear (depending on the amount of gas and other stuff inthe trunk).
Old Jul 11, 2001 | 11:59 AM
Rod's Avatar
Rod
Originally posted by SLVRTSUNAMI:
<STRONG>the Eibach pro kit springs (they are the Accords BTW) wilol give you a little raked stance at about 1.5-1.75" up front and about 1-1.5 in the rear (depending on the amount of gas and other stuff inthe trunk).</STRONG>
I believe the Pro-Kit is more like 2" front/1.75" rear. People that have them usually agree on 2" all they way around though. In the pics I've seen of CLs with the Pro-Kit, the ass seems to be sagging, which is why I went with monopolistic Comptech.
Old Jul 11, 2001 | 01:41 PM
jdl75's Avatar
Originally posted by Southpaw:
<STRONG>do u have to replace the stock shox if u want to add lowering springs?</STRONG>
Careful!
1. If you lower the car too much, the shocks run the risk of smacking - forcibly compressing the shock too much. While the shocks are out, check this - if there is any way for the spring to compress far enough, you will have a problem.
2. The new springs will have a new spring constant or k factor - this is the rate of force generated per unit of length compression. This factor in usually expressed in N/m (Newtons per meters) or lbf/ft (pound[force] per foot). Changing this affects damping ratios for decent suspension performance.
You may find that the car will feel springy, as the shocks will be undersized for the spring. As the spring is shorter, lowering the car, the spring constant must increase to keep the car from bottoming. If you care, the equation is as follows:
f = mx" + bx' + kx
f = force generated
m = mass of the [wheel]
x" = acceleration of the [wheel] upward
b = damping ratio of the shock
x' = velocity of the [wheel upward]
k = spring constant
x = displacement of the [wheel upward]
translated, the thing will slide, as the wheels won't be on the ground. HELLLLLOOOO understeer!
[ 07-11-2001: Message edited by: jdl75 ]
jdl75's Avatar
Old Jul 11, 2001 | 04:10 PM
Southpaw's Avatar
thanx alot guys i will take all of this into consideration since its a lease i might just say fuck the shocks , my lease is up in 36 mo. i saw a pic in here the guy had comptech springs and 18x7.5 wheels and it looked really tight. to tell u te truth i got stock shocks on my max with h&r springs and the car has 50k on it.
Old Jul 11, 2001 | 04:57 PM
dlew308's Avatar
I had 65k miles on my lowered prelude...didn't replace shocks. Same with a civic....*knock on wood*
MrHeeltoe
20
Feb 23, 2023 01:54 PM
emailnatec
29
Sep 28, 2018 04:27 PM
CarlosILX13
ILX Performance Parts & Modifications
14
Jul 11, 2016 11:07 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
