Motor Mounts
Old Aug 20, 2004 | 05:17 PM
MrMicrophone's Avatar
Motor Mounts
Okay, so I just got a new front motor mount for my '01 type S. Can anyone tell me what the torques are for the mounting bolts and, especially, for the stud on the top of it? I'd like to get it in this weekend.
thanx
Old Aug 21, 2004 | 09:37 AM
ChadT's Avatar
Spectacular Aroma About
40 ft lbs
Old Aug 21, 2004 | 10:24 AM
Excellent
Thanks!
Old Aug 22, 2004 | 02:06 AM
Ogolden1's Avatar
Oh...Behave!
thanx
Did you order it thru the dealer? ...How much was it?
Old Aug 22, 2004 | 09:44 AM
I got it through www.acuraautomotiveparts.org It was about $72 plus shipping & handling.
I wouldn't recommend changing your own if you don't have a cherry picker to take the weight of the motor off, otherwise is isn't too bad of a job. It is easy to cross-thread the mounting bolts if you don't get them all started before putting any weight on the mount.
Old Aug 22, 2004 | 10:31 AM
Ogolden1's Avatar
Oh...Behave!
Thanks for the info! I don't have a cherry-picker ...I was planning on using a floor jack and a block of wood to lift the motor.
Old Aug 22, 2004 | 11:19 AM
That was my first thought, but you really need to get under the car to loosen one of the mount bolts and one of the bolts on the bracket that attaches to the motor itself. If the jack is there, it will be hard to crawl under the car. I'm just saying, you can probably do it that way, but plan out the order of steps before you find yourself stuck.
Old Aug 22, 2004 | 03:38 PM
Okay, as if anywone cares, I am really pissed now... The closest Acura dealer is an hour away (welcome to nowhere), so when I developed a clunk out of warranty, I took the car to the Honda dealer. They replaced the rear motor mount, then announced "now that we have fixed that, we realize that the front mount is bad too." I called "bullshit" and replaced the front mount myself. Now, nearly $500 later, the clunk is in NO WAY any different than it was before.... this sux.
Old Aug 22, 2004 | 03:45 PM
Ogolden1's Avatar
Oh...Behave!
The clunk is probably in the CV joint/axle bearings. I have already been thru this stuff once. Now, 40k miles later, I'm going thru it again! ...Too much power and a heavy foot!
Old Aug 22, 2004 | 04:47 PM
916CL's Avatar
how can you tell if you have a bad mount
Old Aug 22, 2004 | 07:12 PM
Ant7701's Avatar
Sweet as Gold
You can do the front mount w/ a floor jack just fine. First remove the four bolts that hold the motor mount to the sub-frame. Then remove the 17mm bolt that goes driectly thru the side mount. then remove the 17mm nut on top of the front motor mount. Then jack up the engine and pull out the motor mount. i do it ALL THE TIME. When lowering the engine down on the new mount go slowly and use a long screw driver the line-up the holes. and then just re-install the bolts..
Old Aug 28, 2004 | 11:23 AM
The front mount I replaced was the one near the radiator. It sounds like you're describing the one nearest the wheel.
Old Aug 28, 2004 | 11:26 AM
Here's an update... after a semi-drunken e-mail to the dealer, they called me and had be bring the car back in. They found the radius rods needed re-torqued which completely fixed the problem. They defended replacing the rear mount, but don't have the "bad" part to support it. That also means I don't have the part to prove that it didn't need replaced. They didn't charge me to fix it, but I already paid them over $400 for the mount.
Oh well, at least it is fixed.... now for the transmission recall on my second transmission...
Old Aug 28, 2004 | 01:32 PM
Ogolden1's Avatar
Oh...Behave!
Radius Rods
They found the radius rods needed re-torqued which completely fixed the problem. ...
What are the "Radius Rods"???
Old Aug 28, 2004 | 03:27 PM
They are a suspension part on each side that connect to the knuckle. It is easies to see if you go to www.acuraautomotivepart.org, go to Acura parts, look up your model then look under "front lower arm". You can see the picture of them. I don't know what the proper torques is, but they didn't seem loose, but tightening them did fix the problem.
Old Aug 28, 2004 | 03:36 PM
ChadT's Avatar
Numbers 6 and 8 in this picture.
Old Aug 28, 2004 | 07:02 PM
or someone can do it for you ; )
Old Aug 28, 2004 | 09:48 PM
Ogolden1's Avatar
Oh...Behave!
Thanks guys!
08KBP_VA
Oct 22, 2019 01:55 PM
Jul 16, 2017 07:33 AM
juanrl
Sep 29, 2015 03:25 AM
xsilverhawkx
Sep 28, 2015 06:51 PM
