Mobil1 oil filter (Extended Perf. vs. regular)
I went to PepBoys, and found two versions of M1-104 oil filter, one is regular Mobil 1 oil fileter,and the other one (black) M1 Extended Performance.
the price is the same, I wonder if those filters are the same... just a different packaging....
The extended-performance filter is their latest one. The "regular" M1 filter has been discontinued for months now, so what you're seeing is old stock you ought to avoid.
The new extended-performance filter has been significantly improved over the previous one to maintain the same high-efficiency during a longer service interval. Capacity has also been improved.
I use Mobil 1 oil and M1 oil filter, and change oil every 6K miles. I think now I can push it to 7K miles (or 1yr). Because thats how many miles I put in one year...
info I found on mobil1
Mobil 1 High Efficiency Oil Filters
The Mobil 1 High Efficiency Oil Filter is the most advanced oil filter available for consumers today, offering unsurpassed filter durability and exceptional filtration capability. When used with Mobil 1 Synthetic Engine Oil, this filter provides the ultimate in engine wear and cleanliness protection. Mobil 1 Oil Filters remove more contaminants via a substantial improvement in multiple pass filter efficiency (95% vs. 80% for conventional filters) by using a synthetic fiber media. ....
Amsoil 98.7 % at 15 microns
Mobil1 95%
let the oil filter wars continue,, we benifit by this
Mobil1 95%
Mobil1 95%
Mobil1 95%
I think you have old info on High Efficency oil filter.
Mobil1 extended performance filter multi-pass is 99.2%.
It even says on my filter box, and here is info. from mobil1:
http://www.mobil1.com/USA-English/Mo...ters_FAQs.aspx
Does ExxonMobil make oil filters for use with Mobil 1?
ExxonMobil does offer a very high-quality oil filter that can be used with any motor oil, but it is an especially appropriate companion to Mobil 1. Mobil 1 Extended Performance Oil Filters contain synthetic fibers instead of the typical cellulose filter media. With a 99.2 percent efficiency rating (under SAE J1858 Multi-Pass Efficiency Test), the Mobil 1 filter is much more efficient than a typical oil filter, removing more particles per pass through the filter. In addition, the synthetic fibers in the Mobil 1 filter have less resistance to oil flow, reducing the potential for the filter to restrict the flow of oil to your engine.
If we don't consider prices and assume that Amsoil don't lie on their numbers,
I agree that Amsoil products are better than Mobil1.
But considering the cost (plus shipping), to me its not worth the money...
When I see Amsoil being used in "Original Factory Fill" for Corvette and Mercedes, then I will consider it. But for now, I'll stick with Mobil1 :-)
I would also keep it for 10K miles, but I drive only 7K miles a year, and don't want to keep the same oil longer than 1 year.
Amsoil's filter does have the industry leading media and design for the best compromise of both capacity and efficiency over a long drain interval. The limited results I've seen have shown the filter to be excellent.
However, the differences between the Amsoil and Mobil 1 EP filters are minimal at best, especially for the shorter drain intervals. If you're after the best, then the Amsoil filter is the way to go for 30% more.
Amsoil does not make too much sense if you put low miles and have to change your oil once a year.
don't forget the shipping costs....
I will research this some more,, Amsoil filters wholesale (for me) are about 12.50,, retail for about $15,,
How much are the Mobil1 ?? I use the best I can find,, I drive 25k miles per year..
Also comrad the oil doesn't go bad after a year (synthetic) just the filter,, it is easier just to change everything at once.
very nice info
Going beyond one year on the same oil is pushing (even synthetics).... some study said it starts to accumulate moisture and etc. Especially if you make a lot of short trips and live in a crazzy north east climate... Perhaps if you drive 1000 miles a year or less, keep your car in a garage all the times, and live in California... then it migth be OK to go beyond 1 year on the same oil.
Even Amsoil warranties their oil for 25K miles/ 1 year, the same for Mobil1 extended performance oil: 15K miles / 1 yr .
M1 Extended Performance filter is $11, and I can get it from PepBoys or Autozone, but with Amsoil I need to find a local dealer to buy it for $15, otherwise I have to pay for shipping.
IBankMouse
Jun 13, 2020 12:53 PM
SidhuSaaB
May 30, 2020 12:40 AM
STL TL-S
Sep 23, 2015 08:52 PM
